Understanding AIDS Detectors: Key Principles of Clinical Use
  • Thread starter Thread starter eagleone
    Detectors
The discussion revolves around the principles and methods used in clinically detecting HIV, the virus associated with AIDS. Participants explore various detection techniques, their effectiveness, and the implications of using different technologies in clinical settings.
  • Some participants clarify that AIDS is a syndrome and cannot be detected directly, but rather through the detection of HIV.
  • It is proposed that HIV tests primarily detect either the virus through PCR or antibodies through methods like ELISA.
  • One participant explains the ELISA technique in detail, describing the process of detecting antibodies in blood samples.
  • There is a suggestion that faster diagnostic methods, such as sensitive spectroscopy, could be more effective than current techniques.
  • Some participants express an expectation for high-throughput methods, such as chips, to be used in HIV detection.
  • Concerns are raised about the cost-effectiveness of chip analysis compared to traditional methods like ELISA and PCR, particularly regarding sample waste.
  • Participants discuss the optimization of existing methods (PCR and ELISA) to minimize false results, while also considering the potential of newer technologies.
  • One participant shares personal experience with genome expression studies and the costs associated with chip technology, questioning its practicality for HIV detection.
  • There is a mention of the preference for established methods over newer alternatives, despite the availability of potentially better technologies.
Participants express differing views on the effectiveness and practicality of various detection methods for HIV. There is no consensus on which method is superior, and the discussion remains unresolved regarding the best approach to HIV detection.
Participants note limitations related to the cost of newer technologies, the need for sufficient sample sizes, and the historical optimization of existing methods. These factors contribute to the ongoing debate about the most effective detection strategies.
eagleone
What are basic principles of clinically used AIDS (from blood) detectors ?
Biology news on Phys.org
Well, first of all: AIDS is a syndrome, it cannot be detected by a test.. rather it is a combination of symptoms that give the diagnosis.
What you mean to say is how HIV (Human Immunodeficiency
Virus) is detected :)
I am not sure, it could be a multiple techniques.. let me look around..
There are basically two things that the test can detect: the virus by PCR (which hides inside of cells, not a very good target) or antibodies. A HIV test would detect these antibodies from blood. The problem though is that it takes three months for most people to generate enough antibodies that can be detected..
The test is ELISA (enzyme linked immunosorbent assay). I am not sure if you are familiar with this technique? Basically an antigen is placed into wells of a microtiter plate, then a purified sample of blood is added (with the potential antibodies). A second antibody, which is covalently linked with horseradish peroxidase is then added, which will amplify the signal of the first antibody. An enzyme is then added, if the horseradish peroxidase is present
(after washing steps) a color will develop, indicating a positive sample.
Interesting site: http://www.aidshivtest.com/ I guess it is based on the same technique as described above?
Good link,
well, I guessed it could be done by that way, nevertheless I expected some more “physical” diagnostic method (faster.. maybe some sensitive spectroscopy).
AIDS test-> yes, mistake -> speeding ticket :)
I actually would have expected a high-throughput method like chips..
Yes of course, chips are under "must be included", for any modern and quanitative equipment :).
I just think that they don't post on the net all the tehnical and engineering data, I'll search for a better url...
greets!
Do you know how much a chip analysis cost compare to ELISA and PCR? You got the reason why they are using "older" methods rather than newer technology. You also require many sample for chips. Are you going to waste 1 chip for 100 people? It is not cost effective.
They are probably doing research on using chip and to minimize the false posisitive and false negative. PCR and ELISA having been used for more year and are optimize to have a minimun of false results.
I have done a whole genome expression study, using the HG-U133 A and B chips from Affymetrix, I am aware how expensive the chips are.. $2000 if I remember correctly.. I am not sure if that is just for A or for A and B. And that is without the cost of sample preparation and such.
Anyway, that is a whole genome thingie. For the HIV test, you've got much less target to worry about. I think it is not too difficult to optimize detection for such a thing as you say it would be. Sample size shouldn't be a problem, but that is depending on the impact of HIV on a region..
People just like to stick with things they know that work. I myself have done a LOT of work with radioactive isotopes, but good alternatives are available with fluorescent materials which can be automized too.. my boss didn't agree and rather had it done the old fashioned way.
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 0 ·
