Register to reply
3D Scanner using static electric fields
by taylaron
Tags: electric, fields, scanner, static
Share this thread:
taylaron
#1
Oct24-13, 03:22 PM
PF Gold
taylaron's Avatar
P: 384
Greetings PFers,
Can someone help explain to me the difficulties of designing a device which utilizes static electric fields to map an objects’ internals and externals?
My understanding is that as a electric field propagates through matter, it encounters absorption.
I envision a device which utilizes a RF emitter and a sensor 180 degrees opposite the object being scanned. Wouldn't this scanner function much like a CT scanner? As the field penetrates more matter, its field strength decreases a measurable amount.
Conductive objects would make scanning difficult because they would conduct the electric field, instead of impeding it.
-Tay
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
mfb
#2
Oct25-13, 04:52 AM
Mentor
P: 11,631
All objects are conducting, there are no perfect insulators.
I'm not sure how the object reconstruction would look like, and you will certainly need a lot of data points and sender/receiver combinations, together with a very good timing resolution (<< nanosecond) to detect the RF phase. And it fails if too much metal is in the object, of course.
RF fields are not static, by the way.
taylaron
#3
Oct25-13, 07:43 PM
PF Gold
taylaron's Avatar
P: 384
Quote Quote by mfb View Post
Sorry, I thought I removed all references to RF fields. I changed my position to static electric fields instead.
Without having to worry about sub nanosecond accuracy with static fields, I still see conductive objects as being an obstacle, but surely an algorithm can be used to solve most of that problem. Any other thoughts?
-Tay
mfb
#4
Oct27-13, 06:43 PM
Mentor
P: 11,631
I still don't see how you want to do a proper 3D reconstruction. It will be highly non-trivial to distinguish parts of the 3D object with static fields.
Register to reply
Related Discussions
Static electric and magnetic fields and energy. General Physics 3
Static situations and electric fields - special relativity Advanced Physics Homework 0
Static electric fields Classical Physics 3
Static Electric Fields / virtual photons / Ionization Quantum Physics 2
Why black holes can have static electric fields? Special & General Relativity 4
