How do I find the area between two curves with one function not always on top?
  • Context: Undergrad
  • Thread starter Thread starter ashleyk
    Area Curves
The discussion revolves around finding the area between the curves y=x and y=1/(x^2) bounded by x=2, with particular focus on the challenges posed by the curves not consistently being on top throughout the interval. Participants explore different approaches to defining the area, considering various bounds and intersections.
  • One participant suggests that the area should be calculated by integrating the top function minus the bottom function, but expresses confusion due to the curves not being consistently ordered.
  • Another participant proposes that the point of intersection might serve as a necessary bound for the area calculation.
  • Several participants discuss the need for a lower boundary, with one suggesting that y=0 could be considered as such.
  • One participant outlines a method to treat the area as two separate regions based on the intersection point at (1, 1), detailing the areas to be calculated.
  • Another participant questions the clarity of the problem, noting that the area between the curves is not well-defined due to overlapping regions.
  • One participant mentions obtaining an area of 1, assuming y=0 is the lower boundary, and expresses uncertainty about this assumption.
  • Another participant describes the presence of multiple regions and suggests that the area calculation is complicated by the curves intersecting and overlapping.
  • Some participants provide integrals for calculating the area, but there is no consensus on the correct approach or final answer.
  • One participant mentions a logarithmic result from integrating, indicating a different perspective on the area calculation.
Participants do not reach a consensus on how to define the area between the curves, with multiple competing views and methods presented. The discussion remains unresolved regarding the correct approach and final answer.
There are limitations in the problem definition, particularly regarding the lower boundary and the treatment of overlapping curves. Participants express uncertainty about the assumptions needed for the area calculations.
ashleyk
Find the area of the region bounded by the curves
y=x , y=1/(x^2) , and x=2
I know after you sketch it you have to take the intergral of the top function minus the bottom function from the points that they intersect. I am stuck however because one function does not appear to be on top throughout the interval. Any help would be great...
I'm thinking that since there was no other bound (you can't assume the y-axis is a bound), I imagine their point of intersection is meant to be taken as the other bound for the function.
The attached plot is the area. It is:
[tex]\iint_R dA[/tex]
Right?
and what about area between x=0 and x=1?
Ok, I see what you mean. Perhaps the problem is not well defined.
The region is bounded by y= x, y= 1/x2, and x= 2.
The only difficulty with that is that there is no lower boundary. I bet the problem also gives y= 0 as a boundary. In that case:
Of course, y= x and y= 1/x2 cross at (1, 1). That is, the region is bounded above by y= x from x=0 to x= 1, then by 1/x2 from x= 1 to x= 2.
The simplest way to do this is treat it as two separate regions:
1) the region bounded by y= x, y= 0, x= 1. In fact, that's a triangle with area 1/2.
2) the region bounded by x= 1, y= 1/x2, y= 0, x= 2.
Integrate y= 1/x2= x-2 from x= 1 to x= 2.
Add the areas of the two regions.
Right?
I think this is a Calc I question, so the poster wouldn't have encountered double integrals yet.
Possible answer?
I got an answer of 1? can anyone verify...??
How did you get 1? In fact, can you tell me what the bottom curve of your region is?
answer of 1
I got the answer of one assuming the bottom is y=0...i have to ask my teacher tomorrow for sure if that is suppose to be one of the curves..
i don't know how many curves you people see, but there were (from top of my head - i plotted this in the morning) 4 different regions. you have one between x=0 and x=1 - the one where 1/x^2 reaches to infinity, area is approximately 144+, then between x=1 and x=2 there is a triangular area and a parabolic area over on top.
so this question is not very well defined. you can't really find an area 'between' curves per se- as there are interlapping curves
I'm 99% sure the region is meant to be this one (in really crappy, fast sketching)...
the intersection of y=1/(x^2) and y=x is at x=1
so the area is the area under the top curve - area under the bottom curve.
A = [I(1 to 2)(x dx)] - [I(1 to 2)((dx)/(x^2))]
I = integral sign
Yes, or course! to both Moo of Doom and IntuitioN. I didn't draw my graph clear enough!
You could also just integrate the difference of the y-values
[tex]A= \int_1^2 (x- x^{-2})dx[/tex]
(that's exactly the same as what IntuitionN gave).
hey,
its obvious from a book i read u equate x and 1/x^2,getting x as 1.this ends up being the lower boundary number,and then integrate definitely the multiple of x and 1/x^2gettiung the integral of 1/x,which becomes log [x].taking the definite step, the answer is log2,in base e.
  • · Replies 20 ·
  • · Replies 24 ·
