Register to reply
Probability of getting a sum of 13
by karthik666
Tags: None
Share this thread:
karthik666
#1
Oct26-13, 06:29 AM
P: 11
Obtain the probability of getting a sum of 13, when four fair dice are
rolled together once.
if we do by just calculating all possible values of sum,then it will take more time.
so,we can do above problem as Multinomial Coefficents of sum
i.e.,x1+x2+x3+x4 = 13 where,1<= xi <= 6,for all 1<= i <= 4.
i got stuck that form the above equation how can we obtain no.of.possible ways to get sum = 13.
Thanks for Help.
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
sjb-2812
#2
Oct26-13, 06:35 AM
P: 427
Do you know how to calculate the probability of getting, for instance a 4 when two dice are rolled?
karthik666
#3
Oct26-13, 06:40 AM
P: 11
yes,it's easy,but here we have to find when four dices rolled together..
sjb-2812
#4
Oct26-13, 06:42 AM
P: 427
Just extend the ideas then. How about a 9 with 3 dice?
karthik666
#5
Oct26-13, 06:46 AM
P: 11
your approach is correct upto 3 dice,but u cannot do for 4 dice
sjb-2812
#6
Oct26-13, 08:32 AM
P: 427
Why not?
karthik666
#7
Oct26-13, 10:03 PM
P: 11
it will take more than half-an hour,but in Exam it won't entertain such silly tasks!!
D H
#8
Oct26-13, 10:40 PM
Mentor
P: 15,067
I just did it three different ways and it took less than a couple of minutes, total.
What do you get using your half hour long approach?
karthik666
#9
Oct26-13, 11:52 PM
P: 11
may be u r saying Lie,probaility(saying a Lie)= 0.5..
ok,what is the answer that you got?
D H
#10
Oct27-13, 12:13 AM
Mentor
P: 15,067
Aside: Stop using text speech. It's against our rules. Sentences start with a capital letter and end with one period. "u" is not a word. It's "you". The same goes for "r". Use "are".
Regarding your "Lie", no, that is not the answer I obtained.
You mentioned you know how to solve the probabilities with three dice rather than four. Imagine one of the four dice is red, the other three are white. The red die can come up as 1, 2, 3, 4, 5, or 6, each with probability 1/6. If it comes up 1, the white dice need to total to 12. What's the probability of rolling a sum of twelve with three dice? How do you combine that with the probability that the red die came up as a one? Now do the same for the red dice being a two (with the white dice now summing to 11), the red die being a three (with the white dice now summing to 10), and so on. This should not take half an hour to solve.
karthik666
#11
Oct27-13, 10:31 AM
P: 11
Your Approach is wrong,and This eventually leads to Obvious Wrong Answer!!
The Answer is:25/162.
sjb-2812
#12
Oct27-13, 10:40 AM
P: 427
OK, and how did you get that number?
Can you explain why DH's approach fails?
D H
#13
Oct27-13, 10:46 AM
Mentor
P: 15,067
Quote Quote by karthik666 View Post
That most assuredly is not the answer. Show your work and we can tell you where you went wrong.
karthik666
#14
Oct27-13, 02:19 PM
P: 11
http://math.stackexchange.com/questi...ng-a-sum-of-13
This Link Clearly Shows you all work,
I'm very happy that i Proved That Your Physics Forum Mentor is wrong!!
@D H Mentor:First You work out the question then post appropriate Comment,PLEASE DON'T MISGUIDE a STUDENT.
Thanks For your Concern!!!
D H
#15
Oct27-13, 02:51 PM
Mentor
P: 15,067
In this case it's that other site that is doing the misguiding. He calculated incorrectly. BTW, using the probability generating function is one of the methods to which I was alluding in post #8.
The answer is not 25/162. The correct answer is 35/324. Here's a link that gets that correct answer: http://www.wolframalpha.com/input/?i...faces+total+13.
karthik666
#16
Oct27-13, 03:30 PM
P: 11
What is wrong in his method althrough i checked correctly
PS: we can use Generating Functions also to solve this question!!
D H
#17
Oct27-13, 03:44 PM
Mentor
P: 15,067
It's obviously wrong. Just calculate (x+x2+x3+x4+x5+x6)4. (Better: Ask Mathematica or Wolfram Alpha to do that for you.) The x13 term is not 200. It's 140.
Calculating that polynomial is a rather hard way to solve this problem, and it's also overkill since all you want is the x13 term. If you have a tool such as Mathematica, that it is overkill is somewhat irrelevant. Sometimes brute force just works. Note: A brute force expansion of that polynomial was not one of the methods I used.
Borek
#18
Oct27-13, 05:37 PM
Admin
Borek's Avatar
P: 23,395
Speaking of brute force:
borek@raspberrypi ~/python $ cat dices.py
total = 0
i13 = 0
for d1 in range(1,7):
   for d2 in range(1,7):
      for d3 in range(1,7):
         for d4 in range(1,7):
            total += 1
            if d1+d2+d3+d4 == 13:
               i13 += 1
print i13, total
borek@raspberrypi ~/python $ python dices.py
140 1296
Register to reply
Related Discussions
Conditional probability - Probability of spotting a downed airplane (really basic) Set Theory, Logic, Probability, Statistics 3
Probability question; Conditional probability and poisson distribution Precalculus Mathematics Homework 1
[PROBABILITY] Joint probability function for two DISCRETE variables Calculus & Beyond Homework 1
[probability theory] simple question about conditional probability Precalculus Mathematics Homework 1
HELP geometric probability: area of a square and conditional probability Precalculus Mathematics Homework 4
