SAT II Physics Practice Questions: Force and Energy Concepts
This discussion focuses on SAT II Physics practice questions related to force and energy concepts, specifically involving magnetic forces, the behavior of light, and kinetic energy calculations. Key questions include determining the magnetic force on a proton in a magnetic field, understanding image formation with mirrors, and estimating forces required for circular motion. The discussion emphasizes the importance of applying relevant physics formulas and concepts, such as the Bohr model for atomic energy levels and the wave model of light for explaining observable phenomena.
  • Understanding of classical mechanics, including Newton's laws of motion
  • Familiarity with electromagnetic theory, particularly magnetic forces on charged particles
  • Knowledge of optics, specifically the behavior of light with mirrors
  • Basic principles of energy conservation and kinetic energy calculations
  • Study the formula for magnetic force: F = qvB sin(θ)
  • Learn about the Bohr model of the hydrogen atom and its implications for energy levels
  • Explore the wave-particle duality of light and its applications in optics
  • Review kinetic energy concepts and work-energy principles in physics
Students preparing for the SAT II Physics exam, educators teaching physics concepts, and anyone interested in mastering force and energy principles in classical mechanics and electromagnetism.
Nimmy
A proton charge of 1.6 x 10^-19 coulomb moves trhough a vacuum with a speed v of 1 x 10^6 meters per second. It passes through a uniform magnetic field as shown above. If the force exeted on the proton is 8 x 10^-15 Newton, the magnitude of the magnetic force is most nearly.
(A) 1.3 x 10^-27 T
(B) 2 x 10^-11 T
(C) 5 x 10^-10 T
(D) 5 x 10^-2 T
(E) 20 T
A plane mirror can be used alone to form a
(A) magnifed real image
(B) diminished real image
(C) magnified virtual image
(D) diminished virtual image
(E) virtual image neither magnified nor diminished
The answer is E. Why?
A proton of mass 1.7 x 10^-27 kg and speed of 3 x 10^7 meters per second is moving in a circle of radius 200 meters. Which of the following is the best estimate of the order of magnitude of the magnetic force needed to maintain this motion?
(A) 10^-20 N
(B) 10^-14 N
(C) 10^-8 N
(D) 10^-4 N
(E) 10^0 N
Can you tell me the formula?
On the basis of the Bohr model, it can be predicited that the internal energy of a hydrogen atom will
(A) increase when any frequency of light impinges on the atom
(B) change by any amount as a result of collisions with other hydrogen atoms
(C) change only as a result of the emssion of light
(D) be restricted to certain discrete values
(E) always be the same
Explain how you got the answer?
If thin metallic foila few atoms thick is bombarded by a narrow beam of alpha particles, it will be observed that
(A) all particles pass through undeflected
(B) none of the particles are deflected through more than 45 .
(C) most particles are de flected through more than 45 .
(D) occasional particles are deflected through 180 .
(E) all paricles are defkected through 180 .
Of the following observable phenomena, which can be explained by using the wave model of light, but not the particle model?
(A) Energy is transmitted by a light beam
(B) Pressure is exerted by a light beam
(C) A region reciving light fromt two small coherent sources can have points of zero intensity of light.
(D) All of the energy emitted by an atom as light can later be completely transffered to another atom.
(E) Light incident on a plane reflecting surface at a given angle is reflected at the same angle.
A 12 kg object initally has 24 joules of kinetic energy. How far will the object move against a net resisitng force of 6 N?
(A) 2 m
(B) 4 m
(C) 12 m
(D) 16 m
(E) 24 m
Explain how you got your answer?
For that much work I'm going to have to ask you to do some before I do it for you.
You need to really figure out why. Go problem by problem and tell us what formulas you are going to use and such. I got to say though at least the first one doesn't make sense at all. How can it be 2 and 3 only and also 1, 2, and 3? How the hells that possible llol.
