What is the torque exerted on the disk by the two applied forces?
  • Thread starter Thread starter cavery4
    Torque
The discussion revolves around calculating the torque exerted on a uniform solid disk due to two applied forces. The disk is specified to have a mass of 28.3 kg and a radius of 0.414 m, and it is free to rotate about a frictionless axle. Participants are exploring the effects of two forces, 90.0 N and 125 N, applied to the disk.
  • The original poster attempts to calculate the net torque by multiplying the forces by the radius but expresses confusion over the correctness of their approach. Some participants suggest considering the direction of the torques and the concept of moment of inertia.
Participants are actively discussing the opposing nature of the torques produced by the two forces. Guidance has been offered regarding the use of sign conventions and the relationship between torque and angular acceleration. There is an ongoing exploration of how to interpret the forces in relation to the disk's rotation.
There is a noted confusion regarding the direction of the forces and their resulting torques, as well as the application of the moment of inertia in the context of the problem. The original poster is uncertain about how to apply the relevant equations effectively.
cavery4
A uniform solid disk with a mass of 28.3 kg and a radius of 0.414 m is free to rotate about a frictionless axle. Forces of 90.0 N and 125 N are applied to the disk, as the drawing illustrates.
http://www.webassign.net/CJ/p9-31.gif
What is the net torque produced by the two forces? (Assume counterclockwise is the positive direction.)
What is the angular acceleration of the disk?
For the first question, I thought maybe to do:
90.0 N * r + 125 * r = 89.01
That is wrong.
I know of the eqn.
torque = I * alpha
but I don't know how to use it in this problem.
The two torques are in opposition. Use the sign conventions specified to find the result. Use the net torque to find the acceleration using your last equation. Look up the moment of inertia of a disk rotating about its axis of symmetry.
thank you. how can i see that the forces are in opposition? i am confused b/c the arrows are pointed in the same direction.
The direction of the forces are indeed the same, but in your figure the lower force would tend to make the disk rotate counterclockwise. The upper force would tend to make the disk rotate clockwise. The bracket holding the disk would have to exert a force to the left equal to the sum of the forces pulling to the right. That force is applied to the axis of rotation and produces no torque.
Torque is technically a vector. The direction is the direction of the axis about which the torque is calculated. The torque associated with the lower force would be directed out of the page toward you. The torque associated with the upper force would be directed into the page away from you. In your problem it is sufficient to just call one of the torques positive, and one negative to recognize their opposition.
  • · Replies 21 ·
20K
