Register to reply
Molecules Structure as Planar Graphs?
Share this thread:
referframe
#1
Oct30-13, 11:24 AM
PF Gold
referframe's Avatar
P: 131
I have read that the structure of almost all organic molecules can be represented visually as Planar Graphs, i.e. 2-dimensional lattice-like structures consisting of nodes (points) connected by lines in which no lines cross. From the perspective of Physical Chemistry, does anybody know why this is so? Some graphs are of such complexity that they required 3 dimensions to guarantee that no lines cross - reference "3 Utilities Puzzle".
Phys.Org News Partner Chemistry news on Phys.org
Chemists create nanofibers using unprecedented new method
Nanostructured metal-oxide catalyst efficiently converts CO2 to methanol (w/ Video)
Researchers discover low-grade nonwoven cotton picks up 50 times own weight of oil
mathman
#2
Oct30-13, 03:19 PM
Sci Advisor
P: 6,040
https://www.google.com/search?q=etha...iw=943&bih=672
It is a simplification for showing on a sheet of paper. The above shows that something as simple as ethane has a three dimensional structure.
referframe
#3
Oct30-13, 05:02 PM
PF Gold
referframe's Avatar
P: 131
Quote Quote by mathman View Post
Yes, actually, I was referring to the "simplification for showing on a sheet of paper" rather than to the structure in real 3D space. For most organic molecules, it is possible to represent the topological relationship of the atoms and their connections via covalent bonds on a 2D "surface" - on a plane or on a sphere. From what I have read, organic chemists do not know why this is so.
eigenperson
#4
Oct30-13, 09:37 PM
P: 160
Because most organic molecules do not have the degree of interconnectedness required to be non-planar.
Kuratowski's theorem says that every nonplanar graph contains either a topological K5 or a topological K3,3. In other words, for an organic molecule to be non-planar, you have to either have:
1. Five carbon atoms such that there is a chain (of bonds and atoms) from each one to each of the others, with none of these 10 chains sharing any bonds or atoms with any of the others; or:
2. Two sets of atoms of valence 3 or more, such that there is a chain from each atom in the first set to each atom in the second set, with none of these 9 chains sharing any bonds or atoms with any of the others.
To satisfy either of these conditions, you need a lot of high-order carbons and a lot of different paths between them. That would require a large and highly interconnected molecule. But it's by no means beyond the realm of possibility, and I have to imagine that some proteins, with their abundant disulfide interconnections, are non-planar (containing K3,3). It also seems like some people have synthesized non-planar molecules intentionally: see this article, for example.
EDIT: After posting I found this article which discusses the issue further. The author seems to have a bit of confusion between nonplanarity and knottedness (you can have a knotted molecule that has a planar graph), but apart from that the analysis seems good.
Ygggdrasil
#5
Oct30-13, 11:31 PM
Other Sci
Sci Advisor
P: 1,379
Adamantane comes to mind as a molecule for which this does not appear to be true.
DrDu
#6
Oct31-13, 02:07 AM
Sci Advisor
P: 3,571
Of course there are molecules where this is not true, e.g. adamantane.
The problem with this kind of question is which metric to use:
All organic molecules with a CAS number? All possible organic molecules with, say, up to 100 C atoms?
Borek
#7
Oct31-13, 03:23 AM
Admin
Borek's Avatar
P: 23,406
Quote Quote by referframe View Post
I have read that the structure of almost all organic molecules can be represented visually as Planar Graphs, i.e. 2-dimensional lattice-like structures consisting of nodes (points) connected by lines in which no lines cross. Does anybody know why this is so? Is it due to the properties of covalent bonds?
There is a grain of truth in that, while I think I can imagine some examples of molecules that we won't be able to reproduce this way, most molecules I can think of are "topologically flat" (with all possible disclaimers about them being in fact 3d).
No idea about explanations. And I am not convinced they are strictly chemical.
Quote Quote by Ygggdrasil View Post
Quote Quote by DrDu View Post
Sorry guys, that's incorrect. Adamantan can be drawn flat - hint.
DrDu
#8
Oct31-13, 04:55 AM
Sci Advisor
P: 3,571
Quote Quote by Borek View Post
Gotcha! It is K4, not K5.
Register to reply
Related Discussions
1D Finite Planar Photonic Structure - Transfer Matrix Method Advanced Physics Homework 1
Almost All Graphs are Non-Planar Calculus & Beyond Homework 1
Rather , isomorphic graphs, planar graph Calculus & Beyond Homework 3
4-Coloring Planar Graphs Calculus & Beyond Homework 0
Planar graphs with minimum degree ... Introductory Physics Homework 2
