How Far Must You Be from a Tornado Siren for a 15 dB Decrease in Sound?
  • Thread starter Thread starter Jayhawk1
    Tornado
The problem involves a tornado warning siren emitting sound waves uniformly, with specific sound intensity values given at certain distances. Participants are tasked with determining the distance at which the sound intensity decreases by 15 dB from a known intensity level.
  • Participants discuss the relationship between sound intensity and distance, with some questioning the dimensions of the intensity values provided. Others explore the logarithmic nature of the decibel scale and how to derive the necessary intensity ratio for the 15 dB decrease.
The discussion is ongoing, with some participants providing insights into the calculations needed for part c, while others express confusion about the problem's requirements. There is a focus on clarifying the relationship between intensity and distance, as well as the implications of the decibel scale.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an acknowledgment of potential confusion regarding the specific calculations required for part c.
Jayhawk1
Here is the trouble problem...
11) A tornado warning siren on top of a tall pole radiates sound waves uniformly in all directions. At a distance of 15 m the sound intensity of the siren is 0.39 . Neglect any effects from reflection of the sound waves from the ground. a) At what distance from the siren is the intensity 0.19 ? b) What is the total acoustical power output of the siren? c) At what distance is the sound intensity reduced by 15 dB from its level at 15 m?
a) 21.5 m
b) 1100 Watts
Ok... so I figured out parts a and c, but I have no clue for part c- and the same seems to go for most of my class. I think the change might be very small, but I don't know how to get it. Any help would be appreciated. Thanks!
What are the dimensions of .39 and .19? Knowing that should lead you to an answer for b) I believe the customary dimensions would give you intensity in watts/meter^2. Intensity is the power per unit area, and the area in your case is the total area of the sphere centered at the source.
Sorry... I meant I didn't understand part C... any help?
The decibel scale is based on logarithms. In terms of intensity
[tex]L = 10log({\frac{I}{I_0}})[/tex]
You need to find the intensity ratio that gives you L = -15 and from that determine the distance ratio and then the final distance
  • · Replies 19 ·
