Calculating Moment of Inertia of a Cuboid about the Z-Axis
The moment of inertia (MOI) of a cuboid about the z-axis is calculated using the formula I = (1/12)M(a^2 + b^2), where M is the mass of the cuboid, and a and b are the dimensions in the x and y directions, respectively. The initial calculation provided by the user was correct for the edge axis but needed adjustments for the center axis. The integration limits must be modified to reflect the axis of rotation through the center of the cuboid.
  • Understanding of integral calculus
  • Familiarity with the concept of moment of inertia
  • Knowledge of mass density and volume calculations
  • Basic principles of rigid body dynamics
  • Review the derivation of moment of inertia for different shapes
  • Study the impact of axis of rotation on moment of inertia calculations
  • Explore applications of moment of inertia in engineering and physics
  • Learn about parallel axis theorem and its implications
Students and professionals in physics and engineering, particularly those focusing on mechanics and dynamics, will benefit from this discussion on calculating the moment of inertia of a cuboid.
Nylex
How do I calculate this about the z-axis, if the cuboid length is b in the y-direction, a in the x-direction and c in the z -direction?
In my notes, I have I = ∫ r^2 dm = ∫ (x^2 + y^2) dm
dm = ρdV = ρdxdydz
This is what I did:
I = ∫∫∫ (x^2 + y^2)ρ dxdydz
I = ρ∫dz∫dy∫dx (x^2 + y^2)
I = ρ∫∫dy [(1/3)x^3 + xy^2] {0->a}
I = ρ∫∫[(1/3)a^3 + ay^2] dy
I = ρ∫dz [(1/3)ya^3 + (1/3)ay^3] {0->b}
I = ρ∫dz [(1/3)ba^3 + (1/3)ab^3]
I = ρ[(1/3)zba^3 + (1/3)zab^3] {0->c}
I = ρ[(1/3)cba^3 + (1/3)cab^3]
I = (1/3)ρabc(a^2 + b^2)
and ρabc = ρV = M, so I = (1/3)M(a^2 + b^2)
However, the answer has (1/12) instead of (1/3). Where does the other 1/4 come from??
Thanks.
The moment of inertia depends on the axis about which you want to rotate.
Your calculation is correct for the MOI about an axis that goes through the edge of the cuboid.
The MOI about an axis through its center and parallel with the z-axis is (1/12)M(a^2+b^2).
The limits of integration need a little change...
Daniel.
