Divide By Zero: Is It Ever Logical Not To?
The discussion revolves around the concept of division by zero, exploring whether there are logical scenarios in which it could be considered valid or meaningful. Participants examine the implications of dividing by zero in mathematical contexts, including theoretical and conceptual considerations.
  • Some participants assert that division by zero is inherently illogical, while others question whether it could yield a meaningful result, such as zero or infinity.
  • One participant proposes that dividing a non-zero number by a very small number approaches infinity, suggesting a potential interpretation of division by zero as infinite.
  • Another participant argues that if division by zero were defined, it would lead to contradictions, such as 0=1, which indicates a fundamental problem with such an operation.
  • Some participants discuss the ambiguity of dividing by zero, noting that it can lead to undefined or indeterminate forms, particularly in the context of limits and infinity.
  • There are mentions of mathematical constructs, such as projective planes, where division by zero might be permissible but leads to complications.
  • Several participants express that treating infinity as a number in arithmetic operations can lead to nonsensical results, emphasizing the need for caution in such manipulations.
  • One participant highlights that while some operations involving infinity can be useful in limits, they should not be treated as standard arithmetic.
  • Discussion includes the idea that certain notations, such as limits approaching infinity, may be misleading but are accepted in mathematical practice.
Participants generally do not reach a consensus on the validity of dividing by zero, with multiple competing views presented. There is significant disagreement regarding whether division by zero can yield meaningful results or if it is fundamentally flawed.
Participants express various assumptions about the nature of infinity and division, with some relying on specific mathematical frameworks that may not be universally applicable. The discussion also touches on the limitations of conventional arithmetic when dealing with infinity.
eNathan
Can somebody please tell me any case where it is logical to NOT divide by zero? I know division by zero is illogical itself, but usually when you divide by zero the result should be zero anyway. :rolleyes:
Mathematics news on Phys.org
Try dividing 1 by 0.000000000000000000000000000001. Big number?
Now try 1/(10^-99999) - is that bigger than 0 or close to infinity?
Excellent explanation! Hmn, I actually though of this the other day. I though "hmn, when you divide by 0 shouldn't the result be infinite?" :biggrin:
I just though of an equation where dividing by zero violates something in 'nature' by common sense, but the result should still be infinite.
Let's say I travel 10 meters at a rate of 0 meters per second. The only way this is posible is it I have an infinite amount of time, right? Why isn't [tex]\frac {10 m} {0 mps} = infinite[/tex]? (I know there is a latex symbol for infiinite I just don't know it). But thanks again for that 'infinite' explanation. So my point is, what is wrong with an infinite number?
Where did you get the idea that "usually when you divide by zero the result should be zero anyway." I can't imagine any situation (except under some condition where you have 0/0 but you don't seem to be talking about that) where dividing by 0 could reasonably be interpreted at resulting in 0.
Some people say, loosely, that dividing by 0 results in infinity- but surely not 0!
hmn, well that is why I started this thread because I was not quite sure about it. Like I said, the other day I was thinking about it and I though that the result should either be infinite or 0.
And here we go again.
At least you want to look at it logically.
So, let's do so. When we divide by x where x is any nonzero number, what we're doing is "logically" multiplying by 1/x, where 1/x is the symbol that satisfies x*(1/x)=(1/x)*x=1.
Now, it is easy to show (you should do so) that in any field, it is logical that 0*x=0 for all x.
Thus, if we were to wish for dividing by zero to be defined logically then we should have
0=0*(1/0)=1
so that'd be a problem.
If we wish to divide by zero we need to pass to a larger system that wouldnt't be a field.
Two reasons
First off you got a unique solution to your operation because the nature of the reality (how long does it take to get from here to there) precludes negative numbers. But in general who's to say that [tex]2/0 \ne -\infty[/tex] (infinity is \infty in tex by the way). So you have an ambiguity. But you also have an ambiguity with the square root and we work around that right? In fact if you construct numbers from a projective plane (borrow something by Coxeter from your local math library) you are allowed to divide by zero but in that case
infinity is the same as negative infinitity and addition is not defined on infinity. So this is not a situation you want to be dealing with.
Also if you allow x/0 other questions arrise. Like what is x/0 -y/0. What is 0/0. etc. Then you truly do get problems if you allow those to have answers as seen here http://www.math.toronto.edu/mathnet/falseProofs/first1eq2.html
(Copied directly from site)
Let a=b.
then [tex]a^2 =ab[/tex]
[tex]a^2 +a^2 = ab+ a^2[/tex]
[tex]2a^2 = ab+ a^2[/tex]
[tex]2a^2 -2ab= ab+ a^2-2ab[/tex]
and [tex]2a^2 -2ab= a^2 -ab[/tex]
This can be written as [tex]2(a^2-ab) = 1(a^2-ab)[/tex]
and cancelling [tex]a^2-ab[/tex] from both sides gives 1=2.
So in the end division by 0 is bad because it may lead to greater problems and there is almost no value in allowing division by 0
Hmn I just found a time where zero messes up an equation. We can establish that
if [tex]z = xy[/tex] then [tex]x = \frac {y} {z}[/tex] and [tex]y = \frac {x} {z}[/tex]
But this is NOT true when x or y = 0.
thats where you've got an asymptote in the graph.
eg, the graph y = 1/x is undefined when x=0
Oh ye, if [tex]\frac {x} {0} = \infty[/tex] then [tex]x \ne \frac {x} {\frac{1}{0}}[/tex] But that depends on how you do the math.
eNathan said:
Oh ye, if [tex]\frac {x} {0} = \infity[/tex] then [tex]x != \frac {x} {\frac{1}{0}}[/tex]
Unfortunately you can't just state things like if x/0= because that makes no sence. :-)
your statement x/0 = Infinity is not technically correct, sorry I'm not good at latex so you'll have to make do with shoddey normal writing.
Its better to say that x/0 is underfined or things start getting a bit messed up, becasue otherwise it leads onto saying things like
0/0 = 1
and
Inf/Inf = 1
which is not allways right.
Well I was not stating it as fact. But I do understand this concept of [tex]\frac {x} {0}[/tex] being underfined.
thanks a lot! :-p
I edited my last post ;-) a bit
One more question. [tex]111\infty = 999\infty[/tex]
Is this correct?
hmmm, I'd say no, because it implies that
[tex]\frac {111} {999}[/tex] = [tex]\frac {\infty} {\infty}[/tex]
I'm learning latex ;-)
[tex]\frac {\infty} {\infty}[/tex] can equal all sorts of things, but you really need an equation defined before you can calculate it.
Edit: Like moo said below
You don't really want to do arithmetic operations with [tex]\infty[/tex], but yeah generally it is true that [tex]a*\infty = b*\infty[/tex] so long as a and b aren't zero.
I think we all agreed that division by zero is immoral..
doing algebra with infinities generally turns pretty ugly.
you can say that [tex]\frac {1} {\infty} = 0[/tex] but then things get messed up when you start rearranging that formula to stuff like:
[tex]\infty = \frac {1} {0}[/tex] then start to try doing divisions with this defanition if infinity like: [tex]\frac {\infty} {\infty} = \frac {\frac {1} {0}} {\frac {1} {0}}[/tex]
becasue you end up with crazy stuff like [tex]\frac {\infty} {\infty} = \frac {0} {0}[/tex] which implies that this is the only answer for [tex]\frac {\infty} {\infty}[/tex] which is not technically correct, and also seems to show if you take [tex]\infty[/tex] to be some sort of algebraic argument then it gives [tex]\infty = 0[/tex] which is clearly wrong.
Think of infinities in this case more as some useful device for working out limits of equations rather than some kind of 'number' you can use in algeba.
If a and b = 0 then you end up with 0=0 which is correct. I would argue that this is the only time that [tex]a*\infty = b*\infty[/tex] is correct, because here your suggesting that the two infinities are actual numbers, and are somehow different from each other.
On a similar note, do you consider [tex]lim f(x) = \infty[/tex] (when it is the case) a misleading notation?
I don't see anything wrong with that notation, is this a trick question ? ;-)
You can never assume [tex]0*\infty=0[/tex]. That's indeterminate form.
What I was getting at was more set theory cardinality, like [tex]\aleph_0=2*\aleph_0[/tex].
You see how infinity should not be so manipulated? :P
I have no problem with the notation,as long as you remember that it means "this has no limit" (but in a partcular way).
Sort of. Although you read the equation as "the limit of f equals infinity", its meaning, as pointed out of HallsOfIvy, is different. Which is kind of misleading.
well...i think to solve this you ought not try to use such math above the 4th grade level of schooling...take it by its basic terms
[tex]5/0=x[/tex] which states 5 objects put into 0 groups is equal to a number, which is obviously false, because say x=1, 5 objects put into 0 groups is 1 group...which is obviously false...
Remember that infinity is just a point at the end of the reals (the extended reals, I suppose). This means that the way things behave at infinity is just an inference of how they should behave. IE: as x becomes arbitrarily large, 1/x becomes arbitrarily close to 0. So if x is infinity, 1/x is 0.
This is better stated by the equation:
[tex] \lim_{x \rightarrow \infty} \frac{1}{x} = 0[/tex]
Now note that this limit is approaching from the left (since you can't approach infinity from the right) so x/0 doesn't equal infinity BUT:
[tex] \lim_{x \rightarrow 0+} \frac{1}{x} = \infty[/tex]
The importance is remembering that infinity is not a number, just a behavior as numbers become really large (in so far as limits are concerned, in any case!).
Even in the extended reals, 1/0 is undefined. The limit as you approach 0 from the positive side is different than if you approach from the negative side, so division cannot be extended continuously to (1,0).
That was my point.
I was just saying that when you write infinity, you're really using a limit, and that this limit is approaching from the left (in the case of positive infinity)
That's why 1/infinity = 0 but 1/0 = undefined != infinity, because 1/0 isn't a one sided limit.
I just found a case where x/0 'should' result in 0. Ok you know the graph equation [tex]Y = mx + b[/tex] where m is the slope represented by [tex]\frac {y_1} {x_1} - \frac {y_2} {x_2}[/tex] So we have established that I assume? Now look at this
Using the second equation, when [tex]x = 0[/tex] you have to divide by zero. And the result should be zero to make the graph look right. Correct me if I am wrong.
  • · Replies 40 ·
  • · Replies 36 ·
  • · Replies 18 ·
  • · Replies 16 ·
