Angular Velocity of Merry-go-round
The problem involves a runner jumping onto a merry-go-round, requiring the calculation of the final angular velocity using principles of angular momentum and moment of inertia. The context is centered around rotational dynamics and conservation laws.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of conservation of angular momentum, with attempts to relate the runner's linear momentum to angular momentum. There are questions about the correct formulas to use and how to account for the moment of inertia of both the runner and the merry-go-round.
The discussion has seen participants exploring various formulas and concepts related to angular momentum. Some have expressed confusion regarding the calculations and the necessary components of the moment of inertia. A participant has indicated they found the correct answer after identifying the missing part of the equation, suggesting some progress in understanding.
There is an emphasis on the conservation of angular momentum, and participants are checking assumptions about the initial conditions and the setup of the problem. The discussion reflects a common challenge in applying theoretical concepts to practical problems.
U154756
The problem reads as follows:
A runner of mass m=36 kg and running at 2.9 m/s runs and jumps on the rim of a playground merry-go-round which has a moment of inertia of 404 kgm^2 and a radius of 2 m. Assuming the merry-go-round is initially at rest, what is its final angular velocity to three decimal places?
According to the back of the book, the answer is 0.381 rad/s; however, I can never come up with that answer.
I have tried the following formulas with no luck:
mvr = Iw
1/2mv^2 = 1/2Iw^2 (until I realized kinetic energy would not be conserved.)
I know it has something to do with conservation of angular momentum; however, I cannot seem to figure out the angular momentum of the runner before he jumps onto the merry-go-round. Any help would be greatly appreciated.
[tex]\vec{L} = \vec{r} \times \vec{p}[/tex]
mvr = Iw
Actually, this is the one you need. The initial angular momentum (mvr) equals the final angular momentum. You'll need to find the rotational inertia (I) of the system (merry-go-round + runner).
The angular momentum is the key. You are right about that. I am assuming the runner is approaching the merry-go-round on a tagent line. His angular velocity at the moment of jumping on is his speed times the radius of the merry-go-round, vr. His angular momentum is mvr. That angular momentum will be conserved.
The moment of inertia of the runner plus the merry-go-round after impact is the sum of the merry-go-round plus the moment of inertia of the runner, which is mr^2.
Can you take it from there?
If L = r * p then I have already tried this as it would be the same as L = mvr. I have tried mvr = Iw and solved for w and got the formula w = mvr/I. When I plug the numbers into this formula I do not get the correct answer. Am I missing something?
What are you using for the moment of inertia?
I finally got the correct answer. I hate it when you are on the right track, but can't find the missing part of the equation. My missing part of the equation was the moment of inertia of the runner. After using the formula mvr = (Imgr + Ir)w (where Imgr is inertia of merry-go-round and Ir is inertia of runner), I solved for w and was able to finally come up with the correct answer.
Thanks for your help.
  • · Replies 17 ·
