Lower limit to the diameter
by duder1234
Tags: central pressure, diameter, limit, lower limit, minor, planet
duder1234
duder1234 is offline
#1
Nov3-13, 07:51 AM
P: 4
I have a homework question that I am having troubles with.
Q: By equating the pressure at the centre of an icy planetesimal to the maximum pressure that cold ice can sustain without deforming, about 40 MPa, find a lower limit to the diameter of an icy minor planet.
The part I dont understand is the "lower limit to the diameter"
Do I use: Pcentral >[itex]\frac{GM^{2}}{8πr^{4}}dm[/itex]
I just dont know how to get the diameter....
Phys.Org News Partner Astronomy news on Phys.org
Quest for extraterrestrial life not over, experts say
Continents may be a key feature of Super-Earths
Astronomers discover first self-lensing binary star system
mfb
mfb is offline
#2
Nov3-13, 08:19 AM
Mentor
P: 10,813
I don't know where your formula comes from, but you need some relation between size (like the radius r in your formula?) and pressure in the center, and then let the pressure in the center be 40MPa.
This looks more like an upper limit, however.
duder1234
#3
Nov3-13, 03:57 PM
P: 4
Quote Quote by mfb View Post
I did:
[itex]\frac{dP}{dr}[/itex]=[itex]ρg[/itex]
and [itex]g[/itex]=[itex]\frac{GM}{r^2}[/itex]
so [itex]\frac{dP}{dr}=\frac{-GMρ}{r^2}[/itex] (Hydrostatic equilibrium equation)
and [itex]\frac{dM}{dr}[/itex]=[itex]4πr^{2}ρ[/itex] (equation of mass conservation)
by dividing the two equations: [itex]\frac{dP/dr}{dM/dr}[/itex]=[itex]\frac{dP}{dM}[/itex]=[itex]\frac{-GM}{4πr^4}[/itex]
integration: [itex]P_{c}-P_{s}[/itex]=-[itex]\int^{M_{c}}_{M_{s}}[/itex]([itex]\frac{GM}{4πr^4}[/itex])[itex]dM[/itex]
[itex]P_{c}[/itex] and [itex]P_{s}[/itex] are pressure at centre and surface of the planet
and by setting [itex]M_{c}=0[/itex] and by switching the intergral:
[itex]P_{c}-P_{s}[/itex]=[itex]\int^{M_{s}}_{0}[/itex]([itex]\frac{GM}{4πr^4}[/itex])[itex]dM[/itex]
and
[itex]\int^{M_{s}}_{0}[/itex]([itex]\frac{GM}{4πr^4}[/itex])[itex]dM[/itex] > [itex]\int^{M_{s}}_{0}[/itex]([itex]\frac{GM}{4πr^{4}_{s}}[/itex])[itex]dM[/itex] = [itex]\frac{GM^{2}_{s}}{8πr^{4}_{s}}[/itex]
hence
[itex]P_{c}-P_{s}[/itex]>[itex]\frac{GM^{2}_{s}}{8πr^{4}_{s}}[/itex]
and by approximating that the pressure at the surface to be zero ([itex]P_{s}=0[/itex])
we get:
[itex]P_{c}[/itex]>[itex]\frac{GM^{2}_{s}}{8πr^{4}_{s}}[/itex]
So are you saying I should do:
[itex]40MPa[/itex]>[itex]\frac{GM^{2}_{s}}{8πr^{4}_{s}}[/itex]?
I figure I have to solve for r and then obtain the diameter from there but Im stuck because I am not given the mass... (or do I use a mass of an icy minor planet like Ceres?)
mfb
mfb is offline
#4
Nov4-13, 09:03 AM
Mentor
P: 10,813
Your formula differs from the one in the first post now.
You know the density of ice, this gives the relation radius<->mass,
Register to reply
Related Discussions
Why is Gaussian Packet the lower limit? Quantum Physics 5
lower limit topology Differential Geometry 6
Lower Limit of central pressure in Star Advanced Physics Homework 2
lower explosvie limit Materials & Chemical Engineering 2
lower limit for speed Quantum Physics 4
