Ladder against a wall how simple
  • Thread starter Thread starter ninjagowoowoo
    Wall
The problem involves a uniform ladder leaning against a smooth wall, requiring the calculation of the x component of the force exerted by the ground at the ladder's base. The scenario includes considerations of equilibrium and torque, with specific measurements and angles provided.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss identifying forces acting on the ladder and applying conditions for equilibrium. There is mention of using torque as a method for analysis, with questions about how to express torque in relation to the x-direction force.
Some participants have offered guidance on considering torques and the importance of identifying forces. There is an ongoing exploration of how to express torque and the necessary components involved in the calculations. Multiple interpretations of the approach are being discussed.
Participants emphasize the need for diagrams and proper labeling of forces. There is a focus on ensuring the correct components are used when summing moments, particularly regarding the direction of forces and their contributions to torque.
ninjagowoowoo
OK, so this appears to be a very simple problem... but I can't seem to find the way to do it... Anyway the problem is:
A uniform 6.74 m long ladder of mass 15.6 kg leans against a smooth wall (so the force exerted by the wall, FW, is perpendicular to the wall). The ladder makes an angle = 71.4° with respect to horizontal (see figure below), and the ground is rough.
Calculate the x component of the force exerted by the ground on
the ladder at its base (+x is to the right).
Any tips would be greatly appreciated,
Thanks...
As usual with these kinds of problems, begin by identifying (draw a diagram) all the forces acting on the ladder. Then apply the conditions for equilibrium.
Al since your here maybe you can help us both out. I was looking at this a minute ago and was explaining what you said, but then the idea that torques might be the better method came into my head and I wasn't sure how to explain/include that. What's your take on that?
Yes, you will need to consider torques! (The "conditions for equilibrium" include torques: The net torque about any point must be zero. That's rotational equilibrium.)
How can I find an expression involving torque involving the force in the x-dir? I just can't seem to find it...
Its the perpendicular distance of every force from the chosen axis multipled by that force. So you probably mean the contribution to torque from the force acting in the x-direction. Well chose an axis first and examine the direction of the torque of that force about this axis. Fix signs accordingly and sum all the torques so obtained (for every force).
For your torque equation, pick either the top or bottom of the ladder as your pivot point. Whichever you pick, you'll also need to use the fact that the net force (horizontal and vertical) on the ladder is zero.
Did you indentify and label all the forces acting on that ladder?
I think an important step into this when doing this type of problem, especially when summing moments is making sure you have the correct components. When you sum your torque, say at the top, your weight is acting in the -y direction, however you must remember that you only factor in the component of the weight that is acting perpendicular to the ladder.
Likewise, you will find a force at the bottom of the ladder, but that force will again, be perpendicular to the ladder, so you must find the correct component that you're looking for in the x-direction.
  • · Replies 23 ·
15K
