Thread Closed
Conservation of Momentum and Energy
Share Thread Thread Tools
Oct14-03, 10:44 PM   #1
We are doing Cons. of Momentum in my intro to physics class.. and I am stuck on this problem:
An explosion breaks an object into two pieces, one of which has 1.58 times the mass of the other. If 7370 J were released in the explosion, how much kinetic energy did the heavier piece acquire?
I'm not quite sure where to begin, it seems like the question is misisng some info.. like if the peices are travelling at the same velocity or at different velocities.. I'm guessing this is relating conservation of momentum to conservation of kinetic energy where we can get a variable to cancel out.. but i can't seem to get started.. any hints?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct15-03, 04:37 AM   #2
Let the two pieces be A and B respectively. You need to use conservation of momentum to find out the ratio of velocity of A and that of B first. Since momentum before explosion is zero, so you can use m1v1 = - m2v2.
Let mass of A = 1.58x, mass of B = x.
If velocity ratio of A to B is 1:y, then let velocity of A = k and velocity of B = yk where k and x are constants.
Edit: Now you know their velocities and masses, try to relate them to the energy released in the explosion. The answer to this question can be easily found from here.
Remember conservation of momentum doesn't always imply conservation of energy.
Oct15-03, 09:42 PM   #3
i've been thinking along the lines of ratios.. but the momentum to energy conversion was screwing me up.. (the equations I was coming up with were rediculous!)
in the end, I just looked at the contribution of mass vs. velocity between momentum and energy to solve it..
so between momentum and energy, mass doesnt make any difference since there is a 1 to 1 ratio.. but for velocity, there is power difference (v vs. v^2)..
thanks for the help!
Thread Closed
Thread Tools
Similar Threads for: Conservation of Momentum and Energy
Thread Forum Replies
conservation of momentum vs conservation of kinetic energy Introductory Physics Homework 18
Simulatenous Conservation of Momentum and Conservation of Energy Engineering Systems & Design 9
Conservation of energy or conservation of momentum Introductory Physics Homework 2
Conservation of momentum (with conservation of energy) Introductory Physics Homework 1
Momentum and conservation of energy Introductory Physics Homework 4
