Calculating Moment of Inertia for Compound Pendulum
The discussion revolves around calculating the moment of inertia for a compound pendulum consisting of a meter ruler and attached weights. Participants explore the implications of different mass distributions and the application of relevant formulas for moment of inertia.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate the moment of inertia by considering the ruler and weights separately, questioning the validity of their approach and the formulas used. Some participants suggest that the moment of inertia of the ruler may be negligible compared to that of the weights. There is also discussion about the center of mass and its implications for the calculations.
Participants have provided feedback on the original poster's approach, confirming that adding the moments of inertia for the ruler and weights is a valid method. There is acknowledgment of the need to clarify the center of mass and the mass of the ruler, with suggestions to analyze the system both as a compound pendulum and a simple pendulum.
The original poster notes uncertainty about the mass of the ruler and its effect on the calculations, as well as a correction regarding the weights' mass. This raises questions about the assumptions made regarding mass distribution and its impact on the moment of inertia.
sanitykey
Hi, I'm investigating a compound pendulum and was wondering if this isn't a stupid idea :-p
I have a meter ruler with 2 flat cylinder 1 kilogramme weights sandwiched at the bottom of it securely fastened with a load of cellotape :smile: . The ruler has holes every 5 cm or so, and i found the centre of mass of the ruler is about 21cm.
I was planning to use the [tex]fn = 2\pi^-^1\sqrt(mgrIo^-^1)[/tex] and came to realize that i hadn't a clue what Io was, looked it up, and had a go at trying to find something to work it out. I thought if i found the moment of inertia for both the ruler and the weights separately and added them together it'd be ok
So i found quite a few formulas for rigid bodies, one of them looked like a general one but i didn't know how to do the integration, so i found this one for a ruler shaped object and thought hurray!
[tex]Icm = \frac{1}{12}mr(a^2 + b^2)[/tex]
Then realized it was only for an axis running through the centre of mass, but i was going to have the axis at different spots, but then found this other formula which seemed to sort that out and thought hurray! Since all the holes drilled are along the middle then if i used a hole not running through the centre of mass, it'd be parallel to the axis that could run through the centre of mass right?
[tex]I = md^2 + Icm[/tex]
And then i was dead tired, and thought it'd just be ok if i used the general
[tex]I = mr^2[/tex]
For the weights, and so if i added both of those I values together would that give me a okish value for Io or is it all terribly wrong :rolleyes: ?
Cheers
Richy
You have all the ingredients you need. The idea of adding the moments of inertia for the stick and the "flat cylinders" (disks) will work for you. Finding the moments of inertia about axes that are not the center of mass of each object by using
will work for you. You need to apply this for both the disk and the stick.
How is the center of mass of the "meter ruler" at 21cm? (Or is it not a meterstick?) Also: What's the mass of the ruler compared to the 2 kg masses?
Sure, but it's probably overkill, since the moment of inertia of the ruler is probably small compared to that of the masses.
It's good, but even more overkill. If you insist on including the rotational inertia of the ruler, just treat it as a thin rod.
That's the parallel axis theorem. Good!
[tex]I = mr^2[/tex]
Sounds good to me.
But this is not much of a compound pendulum, since the mass is concentrated, not distributed. You can probably get away with treating it as a simple pendulum. In fact, do the analysis both ways and compare!
Oh sorry :redface: i meant with the weights already attatched the centre of mass appears to be about 21cm from the end that they're put, hopefully it'd be around 50cm if i took the weights off, unless i got a dodgy meterstick. Not sure what the meterstick mass is yet, i'll find out soon though! It's probably about 0.4 kilogrammes i reckon. Thanks a load for all the feedback Olderdan and Doc Al this is really helpful! I'll try comparing the analysis both ways too as you suggested, sounds like a good way to show improvement and maybe get a few more marks :biggrin:
Also just noticed another mistake they're not 1 killogramme they're 0.1 killogramme :blushing: i guess that might change the situation more than i expected (only a 1800 gramme difference...doh!), i know it'd make the mass more distributed, do you reckon everything would still work alright?
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 28 ·
