Register to reply
Asteroid hitting earth
by dannyod6504
Tags: asteroid, degration, earth, hitting, meltingpoint, physics
Share this thread:
dannyod6504
#1
Nov5-13, 02:00 PM
P: 2
I am trying to figure out an equation that will allow me to calculate the mass lost of an asteroid that is coming towards earth. I know what I need to know the melting point of the asteroid, in this case we are using a completely spherical iron asteroid. Also kinetic energy would most likely be a factor along with drag force. I just need to know how much mass is going to be lost after the asteroid enters the atmosphere.
Phys.Org News Partner Astronomy news on Phys.org
Fermi satellite detects gamma-rays from exploding novae
Research finds numerous unknown jets from young stars and planetary nebulae
Image: Hubble serves a slice of stars
dannyod6504
#2
Nov5-13, 02:49 PM
P: 2
Possibly even a more a simple question that I would appreciate is if anyone knows how to convert joules to Celsius
Chronos
#3
Nov5-13, 03:07 PM
Sci Advisor
PF Gold
Chronos's Avatar
P: 9,387
1 degree Celsius equals about 1899 Joules. I'm unsure that will be much help in answering your original question. A body passing through the atmosphere 'loses' mass in two basic ways - ablation and fragmentation. You may find this article of interest http://onlinelibrary.wiley.com/doi/1...04653/abstract
jbriggs444
#4
Nov5-13, 05:51 PM
P: 907
Quote Quote by Chronos View Post
One Celsius heat unit is the quantity of heat required to raise the temperature of one pound of water by one degree Celsius. This is approximately equal to 1899 Joules.
It is not possible to convert degrees Celsius to Joules.
Simon Bridge
#5
Nov5-13, 06:05 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,482
[QUOTE=jbriggs444;4563031]One Celsius heat unit is the quantity of heat required to raise the temperature of one pound of water by one degree Celsius. This is approximately equal to 1899 Joules.[\quote]
Given specific heat in the right units.
Strictly, 1C is the temperature change of 1lb of water whet it receives 1899J of heat.
Which seems an odd number until you realise that the pound is not a metric system unit.
That would be correct - not directly - temperature and heat are different things.
That's what doesn't help OP... so what would? ;)
Simon Bridge
#6
Nov5-13, 06:14 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,482
Quote Quote by dannyod6504 View Post
the usual model for this sort of thing assumes that all the mass lost is [i]vaporized[i].
so you need the melting and vapor points as well as the specific heats and latent heats.
The energy to do this comes from the initial kinetic energy and the gravitational PE lost in the fall.
Only a proportion of this energy will go to ablating the asteroid - so you need a model for that.
The mechanism for the heating will be atmospheric friction.
That should give you enough to get started.
Register to reply
Related Discussions
Asteroid hitting Venus Astronomy & Astrophysics 1
Destroy of Earth by asteroid Astronomy & Astrophysics 8
Asteroind Hitting The earth Introductory Physics Homework 3
Asteroid and Earth Angle Introductory Physics Homework 2
Momentum of an asteroid / Earth Introductory Physics Homework 1
