The discussion revolves around the statement regarding the isomorphism of two finite field extensions F1 and F2 of a field K, specifically whether the condition of having the same degree over K implies that F1 and F2 are isomorphic as fields. The scope includes theoretical exploration and counterexamples related to field theory.
- Debate/contested
- Technical explanation
- One participant seeks to prove or disprove that if [F1:K] = [F2:K], then F1 and F2 are isomorphic as fields.
- Another participant asserts that the statement is obviously false and suggests looking at examples.
- A participant expresses confusion about extending the proof from field extensions to fields, noting the difficulty with general field isomorphisms.
- A counterexample is provided involving the field extensions \(\mathbb{Q}(i)\) and \(\mathbb{Q}(\sqrt{3}i)\), both of degree 2, to illustrate that they are not isomorphic as fields.
- One participant acknowledges the counterexample and appreciates the insight into exploiting isomorphism properties.
- A hint is given to consider a base field like \(\mathbb{Q}\) where every isomorphism is the identity, suggesting that similar reasoning applies to finite fields with the same number of elements.
Participants generally disagree on the original statement, with some asserting it is false and providing counterexamples, while others are exploring the implications and conditions surrounding the statement.
The discussion highlights the dependence on definitions of isomorphism and the specific nature of field extensions versus fields, as well as the need for careful consideration of counterexamples.
