How to calculate toggle mechanisnm forces?
by Flint
Tags: forces, mechanisnm, toggle
Flint
Flint is offline
#1
Nov6-13, 09:24 AM
P: 4
Hi,
This is not a homework question although I'll admit it could be.
I've searched everywhere trying to work out how to calculate the spreading force of a simple toggle mechanism.
I have a two equal length arms that are hinged together. One end is fixed on a pivot pin and the other can slide along a flat plane but is resisted by a fixed stop. The hinged arms are not quite in line and aligning them would increase their overall length. If I apply a force to the hinge, perpendicular to the base plane, what force along the plane will I get?
Is there an equation I can use? I don't need to consider friction in the pins or sliding surfaces just now.
Help!
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
Ryoko
Ryoko is offline
#2
Nov6-13, 11:42 PM
P: 102
Need a picture. But in general, you usually solve this kind of problem by balancing the torque forces across the pivot.
Register to reply
Related Discussions
Toggle Flip-Flop Counter Engineering, Comp Sci, & Technology Homework 5
Replace traditional toggle lever with magnetic cylinders Mechanical Engineering 5
Comparator hysteresis resistors & toggle rate Electrical Engineering 2
Mechanical Advantage of toggle joint Classical Physics 0
Toggle Joint Classical Physics 1
