Register to reply
Help with circuit board
by neen
Tags: board, circuit
Share this thread:
neen
#1
Nov6-13, 04:22 PM
P: 10
This is a tachometer circuit from an early 80's Honda accord.
I twisted the yellow and blue leads together and was able to get the tach to work (retrofitted into another older Honda that only came with a mechanical tach option). The twisted pair was ran off of the negative of the coil and the black was sent to ground. This caused the pink (resistor?) to overheat to the point that it partially burnt the PCB and melted the solder off. I can easily enough re-solder the circuit but I want to know where I screwed up at...I'm thinking that either the blue or yellow lead needs to be the switched 12v power source. Can you guys point me in the right direction?
Here is the reverse side.
Phys.Org News Partner Engineering news on Phys.org
UConn makes 3-D copies of antique instrument parts
Amazon worker piloted drone around Space Needle
Five next-generation technologies for positioning, navigation and timing
mfb
#2
Nov7-13, 08:57 AM
Mentor
P: 11,589
It would be really useful if you would make a circuit diagram out of that, it is hard to impossible to see where the individual parts are connected, or what exactly they are.
I expect that one of the inputs (yellow or blue) should come from a voltage source (you need some reliable way to power the IC, for example).
Baluncore
#3
Nov8-13, 07:07 PM
Sci Advisor
Thanks
P: 1,748
The heated area of the circuit board is under the pink coloured power resistor. My guess is that the adjacent component is a zener diode, and that together they form a crude voltage regulator. Zener diodes tend to fail short circuit, if that happens the resistor gets the full voltage and overheats. It is unusual for the resistor to fail immediately the diode shorts, but you should check the resistor anyhow.
Check the resistance of the zener diode. If very low in both directions replace the zener with the same part number, (probably between 5 and 9 volts). Resolder the resistor and you should be out of trouble. (I have crossed my fingers for you).
Register to reply
Related Discussions
I'm not sure what circuit board to get? Electrical Engineering 2
Circuit Board Problem Electrical Engineering 24
What is Circle on a circuit board Electrical Engineering 18
Simple circuit board ? Electrical Engineering 4
Circuit board production Electrical Engineering 6
