How do you calculate the distance to the center of mass for connected masses?
The discussion focuses on calculating the distance from mass A to the center of mass for a system of two connected masses, m_a and m_b, separated by a distance L and connected by a massless rod. The moment of inertia ratio I_a to I_b is given as three, leading to the conclusion that mass B is three times heavier than mass A. The calculation involves setting up an equation based on torque equilibrium, resulting in the formula maxm = 3ma(L - xm), which simplifies to find the distance xm from mass A to the center of mass.
  • Understanding of center of mass concepts
  • Basic knowledge of torque and moments
  • Familiarity with moment of inertia
  • Ability to solve algebraic equations
  • Study the principles of torque and equilibrium in physics
  • Learn about calculating center of mass for multiple bodies
  • Explore the relationship between mass and moment of inertia
  • Practice solving problems involving connected masses and rods
Students in physics, mechanical engineers, and anyone interested in understanding the dynamics of connected mass systems and calculating their center of mass.
WY
Hello
I was given a question of 2 masses m_a and m_b whos centres of L distance apart and are connected by a massless rod (so it kind of looks like a dumb-bell). Each ball through its centre has an axis perpendicular to the rod (axiz a and b respectively) and each has a moment of inertia, I_a and I_b respectively. And it is also fiven that the ratio of I_a to I_b equals three.
Okay I worked out the ratio of the masses of the two balls which was the first part of the question and that came out okay, and then the second part looked way to simple and I can't seem to dig up another answer:
b) Find d_a, the distance from ball A to the system's center of mass (Express in terms of L, length of the rod)
is it just L/2 or is it acutally more complicated than this?
Can someone help me out ? Thank you!
Since the two masses are not the same- yes, it's more complicated than that! Imagine trying to support this "dumbbell" by holding at its center of mass- you will need to grip it closer to the heavier weight.
One way to calculate the center of mass is to use the "torques"- twisting force- around that point: Take xm to be the distance from A to the center of mass. Mass A causes a "twisting" equal to its weight times that distance: maxm. Mass B is L- xm from the center of mass and so causes a "twisting" of mb/sub]xm.
Since those masses are on opposite sides of the center of mass, those twists are in opposite directions- and since, by definition, there is no "twist" about the center of mass, they must be equal so that they offset: maxm= mb(L- xm).
Moments of inertia are proportional to mass so "ratio of I_a to I_b equals three" tells you that mb= 3ma That means your equation is maxm= 3ma(L- xm). Notice that the ma terms cancel out. Solve that equation for xm.
Hey thanks for that!
That makes much more sense now!
