Register to reply
Sensors for HHO dry-cell performance monitoring
by polka129
Tags: drycell, monitoring, performance, sensors
Share this thread:
polka129
#1
Nov10-13, 02:28 PM
P: 40
Hello All,
i am working on an HHO dry-cell project for which i need to decide upon the sensors to be used in monitoring the process parameters.
1. some sensor for monitoring and displaying the electrolyte level in the bubbler during experiment.
2. some sensor for monitoring the electrolyte level in the dry-cell.this is very critical.although i have made 2mm holes in the SS 316 L plates(anode,cathode and neutral) in bottom zig-zag arrangement to allow for equal flow and equal leveling of electroylte in each cell.i still need to ensure that this is achieved..what should i do for that? unequal electrolyte level in cells will certainly overheat them.
3. do i need a digital pressure sensor? where do i installl it?i intend to buy a flow/rotameter too.intially will measure the HHO flow rate by displacement method(in the water tub and 1 litre bottle) and have maximum readings for one configuration/experiment. will compare the rotamter readings with this conventional method to find the correction factor and will key that in MS EXCEL.so that this should relief me from performing the displacement method for all those experiment i perform..
4. what sensor to use for reading and monitoring the dry-cell temperature?
Please suggest the appropriate sensors for each .sensors with a digital display would be preferable.
regards,
Phys.Org News Partner Engineering news on Phys.org
Researchers discover cool-burning flames in space, could lead to better engines on earth (w/ Video)
Professors object to FAA restrictions on drone use
UConn makes 3-D copies of antique instrument parts
berkeman
#2
Nov10-13, 05:27 PM
Mentor
berkeman's Avatar
P: 40,714
Thread closed for Moderation...
Register to reply
Related Discussions
Difference between Primitive cell, unit cell and a wigner-seitz cell. Atomic, Solid State, Comp. Physics 18
How to plot actual compressor performance on manufacturer performance chart? Mechanical Engineering 7
Condition monitoring Electrical Engineering 2
Boiler monitoring Mechanical Engineering 6
Hurricane monitoring. Earth 2
