Minimizing an Action Integral: Solving for G(z)
  • Thread starter Thread starter JohanL
    Integral
The discussion revolves around minimizing an action integral related to the path of a light ray in a medium with a varying dielectric constant. The integral involves the function F, which is defined in terms of the variable z, and participants are exploring the implications of Fermat's principle in this context.
  • Participants are examining the relationship between the action integral and the corresponding differential equations that describe the minimization process. There are questions about the clarity of notation and the correctness of the approach taken to derive the equations.
The discussion is ongoing, with participants providing feedback on notation and attempting to clarify the mathematical relationships involved. Some participants express uncertainty about the correctness of their approaches, while others suggest that the equations being used may not be applied correctly.
There are constraints regarding the definitions of the variables and the conditions under which the dielectric function is valid. Participants are also considering the implications of the conditions imposed on the parameters a, b, and d in the context of the problem.
JohanL
If you have an action integral
[tex] \int_{A}^{B} \sqrt{F\mathbf{(r)}} dr [/tex]
and
F=a-bz^2 , b>0, a-bd^2>0
the minimum of the action integral is equivalent to
[tex] \frac{d}{dt}\frac{dG}{\dot{z}}-\frac{dG}{z}=0[/tex]
where
[tex] G=\sqrt{F}[/tex]
or am i doing this in a completeley wrong way?
You jump around a lot with your notation. See if this is clear:
If you have an Integral of this form(where y' is the derivative of y with respect to x):
[tex]\Int F[y , y' , x ] dx[/tex]
Then the function y which minimizes the integral is the solution to this differential equation:
[tex]\frac {d}{dx} (\frac {\partial F}{\partial y'}) - \frac{\partial F}{\partial y} = 0[/tex]
It was those equations i was trying to use...but probably in a wrong way.
To explain my notation i give you the problem:
A light ray's path in a medium with variating dielectricity constant
[tex] \epsilon(\vec{r})[/tex]
between the two points A and B, minimizes, according to Fermat's principle, the action integral
[tex]\int_{A}^{B} \sqrt{\epsilon(\vec{r})} |d\vec{r}|[/tex]
A plane piece of glass with thickness 2d has a dielectricity function which, when the piece is in |z|<=d in a cartesian coordinatesystem, can be written
[tex] \epsilon(\vec{r})=a-bz^2 ,b>0, a-bd^2>0 <br /> [/tex]
Calculate the general form for the light ray's path in the piece of glass.
Solution:
The minimum of the action integral is equivalent to
(But this is probably wrong)
[tex]\frac{d}{dt}\frac{d(\sqrt{\epsilon(\vec{r})} )}{\dot{z}}-\frac{d(\sqrt{\epsilon(\vec{r})} )}{z}=0[/tex]
and with this you get
-1/2(a-bz^2)^(-1/2) * 2bz = 0
and this must be wrong!
  • · Replies 16 ·
