| Thread Closed |
High strength fibers for high pressure tubes. |
Share Thread | Thread Tools |
| Apr20-05, 12:45 AM | #1 |
I have interest in an application involving a very high pressure tube. The pressure a pipe can resist is given by the Barlow formula P = 2*S*t/d, with P the pressure, S the tensile strength of the pipe material, t the pipe wall
thickness, and d the inner diameter. I want to get maximum pressure resistance for the weight of the tube for my application. However, if the tube is made of wound fibers such as carbon fibers, Kevlar fibers, S-glass fibers, you won't have the same tensile strength of the pipe wall material as that of the fibers in longitudinal tension, which can be in the range of 1,000,000 psi. This is because the fibers have to be bound together with epoxy which will reduce the tensile strength of the pipe wall against burst pressures (BTW, how much is this reduction in comparison to the longitudinal tensile strength of the fiber?) So I was thinking, has anyone tried drilling through these fibers longitudinally to create tubes? Since the fibers are quite thin this would create quite thin tubes, but that's alright for my application as I can just bind them together to get more fluid flow. The question is would the tensile strength circumferentially be the same as the tensile strength for the fibers tensed longitudinally? A couple of ideas occur to me. While forming the fiber you could have it form around a thin rod covered with some type of lubricating material so that after the fiber forms, you could slide out the rod to get a hollow fiber. Or you could have this rod have a much lower melting or sublimation temperature than your fiber and raise the temperature so the rod will melt or sublimate then flush the melted or gaseous rod material from within the fiber. Secondly, to test the fibers circumferential tensile strength without having to make the fibers be hollow, you could drill a small hole cross-wise through the fiber. Then send a high pressure fluid through the small hole. You could deduce the cross-wise tensile strength from the Barlow formula by seeing how high the pressure can be before the fiber fails cross-wise. Top view: ----------------------------------------------- ___ ^ / \ | | | Cross-wise tensile strength to be tested. \__/ | v ----------------------------------------------- Tensile strength<------------->known high lengthwise. Side view: Hole drilled downwards through fiber this way: | | And high pressure fluid sent downwards through hole. v ----------------------------------------------- ^ | Cross-wise tensile strength to be tested. | v ----------------------------------------------- (Hole drilled cross-wise; so not visible from side.) Bob Clark |
| May2-05, 09:01 AM | #2 |
rg I have a similar problem. I want to create a large vacuum volume at sea level. This Volume will occupy a sphere 1000 feet in dia. The question is does this have to be accomplished with one layer?
| Thread Closed |
| Thread Tools | |
Similar Threads for: High strength fibers for high pressure tubes.
| High Strength Steel with Corrosion Resistance and High Toughness | Materials & Chemical Engineering | 7 | ||
| High voltage electromachinery - the key to absurdly high power to weight ratios? | Mechanical Engineering | 12 | ||
| High school project to propel a toy rocket as high as possible | General Physics | 7 | ||
| High pressure oxygen | Quantum Physics | 0 | ||
| cooling in high pressure | General Physics | 2 | ||
