How about the energy of crystal in a direct transition?
by hokhani
Tags: crystal, energy, transition
hokhani
hokhani is offline
#1
Nov16-13, 01:51 AM
P: 241
When a photon is absorbed by an electron through a direct transition in a crystal, the crystal momentum of electron would not approximately change. Therefore momentum change of electron would neutralize momentum change of crystal. In other words, the crystal would gain momentum as well as electron. But why we don't consider the energy of crystal in this process (we consider all the absorbed energy only as energy of electron transition)?
Phys.Org News Partner Physics news on Phys.org
Researchers find tin selenide shows promise for efficiently converting waste heat into electrical energy
After 13 years, progress in pitch-drop experiment (w/ video)
Global scientific team 'visualizes' a new crystallization process (w/ video)
DrDu
DrDu is offline
#2
Nov18-13, 01:30 AM
Sci Advisor
P: 3,368
How big is the energy change of a crystal of mass ##M \to \infty## if its momentum changes by ##\Delta P##?
hokhani
hokhani is offline
#3
Nov18-13, 06:58 AM
P: 241
Suppose conduction and valence bands are parabolic with the same curvature. If we were to consider the conservation of kinetic energy before and after absorption, the photon energy must be equal to " change of electron's kinetic energy + change of crystal's kinetic energy). According to our supposition electron velocity and hence it's kinetic energy doesn't change so the change of crystal's kinetic energy is equal to the photon energy. Therefore all the photon energy is transfered into kinetic energy of crystal! Could you please help me?
DrDu
DrDu is offline
#4
Nov18-13, 07:25 AM
Sci Advisor
P: 3,368
No, what I mean is that the crystal's momentum changes from 0 to P and its energy from 0 to ##E=P^2/2M##. If P is finite, E becomes 0 in the limit of infinite mass of the crystal.
So the crystal takes care of the conservation of true momentum, but is irrelevant for energy conservation.
Register to reply
Related Discussions
Isotropic crystal and energy band Atomic, Solid State, Comp. Physics 3
Momentum conservation in a direct transition Atomic, Solid State, Comp. Physics 3
Energy Level Transitions, transition time for e- to change energy states in atom Quantum Physics 11
gel-liquid crystal transition temperature of lipids. Chemistry 0
energy transition Advanced Physics Homework 6
