Oxidation State & Shapes of Ni(CO)4
In summary, Ni(CO)4 has an oxidation state of 0 due to the neutral nature of carbon monoxide ligands. The two possible shapes for Ni(CO)4 are likely a tetrahedral and a square planar structure. While it is possible for oxygen to donate its lone pair instead of carbon, in this case, the ligand always bonds through carbon due to pi backbonding.
Big-Daddy
343
In Ni(CO)4 each carbon monoxide acts as a ligand coordinating to nickel. Suggest two possible shapes for Ni(CO)4; what is the oxidation state of Ni?
The oxidation state of Ni seems to be likely to be 0, because carbon monoxide itself is neutral. But is it always safe to say that the oxidation state of the atoms in a ligand do not change when the coordination bond is formed?
As for the possible shapes, they most likely mean one tetrahedral structure and one square planar structure. But my doubt there is this: with the carbon monoxide ligand, it is ever possible to get the O providing the lone electron pair and thus you could have linkage isomers where O donates instead of C? (After all, even though it is formally positive in the carbon monoxide molecule, O still has a lone pair of electrons.)
This is correct, and the correct way to think about the problem: add up all the charges on the ligands, and enforce neutrality with the metal's oxidation state.
I don't quite understand this. If the ligand is reducing or oxidizing, then the oxidation number of the metal may change. But if you're simply referring to something along the lines of: if I have two Cl- ligands, will the metal be anything but 2+ charged if the overall species is neutral? then the answer is no.
Probably these are the two they're looking for. In fact, nickel carbonyl is tetrahedral. Also, CO always bonds to transition metals through the C. There are a number of reasons for this, most importantly pi backbonding (also known as pi acidity), where the sigma metal-carbon bond is augmented by backdonation of electrons from a filled metal d orbital into the empty CO ##\pi^*## antibond.
1. What is the oxidation state of Ni(CO)4?
The oxidation state of Ni(CO)4 is 0. This is because the overall charge of the compound is neutral, and the oxidation state of carbon monoxide (CO) is -2. Since there are four CO molecules, the total charge from CO is -8. This means that the oxidation state of nickel (Ni) must be +8 to balance out the charge and make the overall oxidation state 0.
2. What is the structure or shape of Ni(CO)4?
Ni(CO)4 has a tetrahedral shape, with the nickel atom at the center and the four CO molecules at the four corners. This is because the nickel atom has a steric number of 4, meaning it has four pairs of electrons around it. The CO molecules are bonded to the nickel atom through a coordinate covalent bond, resulting in a tetrahedral shape.
3. How do you determine the oxidation state of Ni in Ni(CO)4?
To determine the oxidation state of Ni in Ni(CO)4, you can use the following formula: Oxidation State = Group Number - (Number of bonds to more electronegative elements + Number of lone pair electrons). In this case, the group number of Ni is 10 (since it is in the 10th group of the periodic table), and it is bonded to four CO molecules, which are more electronegative than Ni. There are no lone pair electrons, so the oxidation state of Ni is 10 - (4 + 0) = +6.
4. How are the oxidation state and shape of Ni(CO)4 related?
The oxidation state and shape of Ni(CO)4 are related through the concept of electron pair repulsion. The four CO molecules bonded to the Ni atom repel each other, resulting in a tetrahedral shape. This shape allows for the maximum distance between the CO molecules, minimizing the repulsion and stabilizing the compound. The oxidation state of Ni is determined by the number of bonds and lone pairs around it, which is also influenced by the shape of the compound.
5. What are the uses of Ni(CO)4?
Ni(CO)4 is primarily used as a catalyst in chemical reactions, specifically in the production of acetic acid, which is used in the production of plastics, textiles, and other industrial products. It is also used as a precursor to other nickel-containing compounds and can be used as a source of pure nickel metal for electroplating or other applications.
9K
