Register to reply
Entropy generation in chemical reactions
by Urmi Roy
Tags: chemical, entropy, generation, reactions
Share this thread:
Urmi Roy
#1
Nov22-13, 04:33 PM
P: 692
So from the first law for a closed system,
dU=dQ-dW=dQ-PdV
From the second law,
dS=dQ/T + Sgenerated (i.e. the entropy generated)
Putting expression of dQ from second law into first law,
dU=T*dS-T*Sgen-PdV
If s and v are constant,
dU= -T*Sgen>0
Hence dU<0
This is a derivation that was given in class
My questions are as follows:
1. When we say s is constant, does it mean there is not heat flow into/out of the system?
2.If dU<0, does the temperature decrease? I find it hard to understand how there can be a positive Sgen and decrease in temperature/ internal energy simultaneously!
Phys.Org News Partner Engineering news on Phys.org
Student develops filter for clean water around the world
Developing the next evolution in underwater communication
Compact vibration harvester power supply with highest efficiency opens door to "fix-and-forget" sensor nodes
DrDu
#2
Dec4-13, 02:46 AM
Sci Advisor
P: 3,552
Quote Quote by Urmi Roy View Post
1. No, you can imagine that dQ=Sgen/T
2. What happens if you mix salt and ice in a thermo jar?
Urmi Roy
#3
Dec8-13, 10:46 PM
P: 692
About your Q2...not too sure, but I know that having a salt in water lowers the freezing point of water...So the ice melts back?
DrDu
#4
Dec13-13, 07:58 AM
Sci Advisor
P: 3,552
Yes, and gets cooler!
Register to reply
Related Discussions
Understanding entropy generation... Classical Physics 1
Another: Simple Displacement Reactions & Balancing Chemical Reactions Biology, Chemistry & Other Homework 1
Chemical Reactions Biology, Chemistry & Other Homework 3
