Calorific value of Petrol
by ruzfactor
Tags: calorific, petrol
ruzfactor
ruzfactor is offline
#1
Nov23-13, 10:23 PM
P: 82
Hi
I am bit confused regarding the heating/calorific value of petrol (used for vehicle) extracted from crude oil and from liquefaction of coal. Should they be same? or Petrol extracted from crude oil will have different calorific value compared to the petrol from liquefaction (direct/indirect) of coal? Could any one please give any reference?
Thanks in advance.
Phys.Org News Partner Engineering news on Phys.org
New ultrasound device may add in detecting risk for heart attack, stroke
Enhanced ground control system and software for small unmanned aircraft
SensaBubble: It's a bubble, but not as we know it (w/ video)
Simon Bridge
Simon Bridge is offline
#2
Nov24-13, 05:03 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 11,114
They are different substances (mixtures) after all.
Different petrols will have different calorific values even if they are all made from oil.
http://www.engineeringtoolbox.com/fu...l#.UpKFmzztkjA
But the properties of individual hydrocarbons wont depend on how you got them.
ruzfactor
#3
Nov24-13, 05:14 PM
P: 82
Thanks for the reply. The link you referred gives heating value of many fuels. Is there any source where I can get heating values of petrol extracted from crude oil and, from liquefaction of coal. Are they really different?
Simon Bridge
#4
Nov24-13, 07:50 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,114
Yeah - the idea was to show you that heat output varies a lot between petrochemicals - you can easily see that different mixtures will produce different values.
Modern direct-liquifaction plants can manage 60-70% of input coal calories to the resulting fuel.[1]
Anthracite coal is very shiny, repels moisture, calorific value 7,800 – 8,000 kcal/kg.[2]
... so you can do the math.
[1] http://www.netl.doe.gov/technologies...quefaction.pdf
[2] http://www.coalmarketinginfo.com/coal-basics/
AlephZero
AlephZero is offline
#5
Nov24-13, 09:30 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,388
It depends what you meant by "petrol". The petrol you put in your car is manufactured to meet a set of standards for its properties, so it won't wreck your engine. Whatever you make it from, the end product will have the same properties.
But if you take a "random" sample of coal and liquefy it in an uncontrolled way, the end result could be almost anything, from methane gas to heavy oil sludge. The same applies to cracking crude oil.
Simon Bridge
#6
Nov24-13, 10:03 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,114
The liquified-coal "petrol" can be as close to regular petrol as you like of course.
However, it is likely to differ if only a little bit... probably different impurities.
How tight is the domestic petrol standard in different countries anyway?
I suspect that there is a specific goal behind the question... perhaps someone has been making claims about synthetic fuel and ruzfactor wants a reality check? If so - it would be best just to state the claims.
ruzfactor
#7
Nov25-13, 05:13 PM
P: 82
Actually I wanted to know if a country ,for example, chooses to extract petrol from liquefaction of coal over cracking of crudeoil, will the petrol be the same as (in terms of energy content) from crude oil.
etudiant
etudiant is offline
#8
Nov25-13, 07:24 PM
PF Gold
P: 849
Coal liquefaction is a very flexible process, so the end products can be tailored to a desired specification.
Caloric content is a very basic measure, the process engineers would want to tune the composition much more exactly. Issues such as freezing point, viscosity and vapor pressure become important when the end use is in engines.
If you would like a bit more detail, a nice primer is provided by SASOL, currently the world leader in coal liquefaction, here:
http://m.everythingscience.co.za/gra...y-02.cnxmlplus
Register to reply
Related Discussions
Find the calorific value of fuel, given emission data Automotive Engineering 2
Thermodynamics - Calorific Capacity Introductory Physics Homework 1
Car Fuel Problem, calorific values. Engineering, Comp Sci, & Technology Homework 2
Constant calorific value problem General Physics 0
Does adding oil on wood increase its calorific value? Mechanical Engineering 3
