Register to reply
Is everything relative?
by quawa99
Tags: relative
Share this thread:
quawa99
#1
Nov26-13, 11:06 AM
P: 63
Is everything we know relative or is there something absolute in this universe?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
ZapperZ
#2
Nov26-13, 11:09 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Quote Quote by quawa99 View Post
This is rather vague. Let's start with something clearer.
Do you know about Special Relativity? Yes? Then what have you concluded from that?
No? Then maybe we can start you with that.
Secondly, what do you mean by "everything"? There are covariant/invariant values and expressions in physics that are NOT relative.
Zz.
quawa99
#3
Nov26-13, 11:14 AM
P: 63
Quote Quote by ZapperZ View Post
Zz.
I just have a basic idea about special theory of relativity.by everything I meant the physical quantities like energy,mass,velocity.
From special theory of relativity I have concluded that velocity of light is the same for all observers so maybe velocity of light is not relative?
Hertz
#4
Nov26-13, 11:14 AM
P: 149
The speed of light is absolute. So is mass. The charge of an electron is absolute. Etc
quawa99
#5
Nov26-13, 11:16 AM
P: 63
Quote Quote by Hertz View Post
Isn't mass relative?
Enigman
#6
Nov26-13, 11:17 AM
Best Humor
Enigman's Avatar
P: 560
Mass is NOT absolute.
##M=\frac{M_0}{\sqrt{1- \frac{v^2}{c^2}}}##
EDIT
Mass, length, time, kinetic energy are all relative.
Charge, spin, baryon no. etc are not relative
Hertz
#7
Nov26-13, 11:17 AM
P: 149
I believe it depends on how you learn special relativity. I learned it as mass being absolute, but I only just learned it in a classroom this semester, so I'm not an expert.
edit-
Quote Quote by Enigman View Post
Why is this necessary?
adjacent
#8
Nov26-13, 11:18 AM
PF Gold
adjacent's Avatar
P: 1,496
Mass?But I heard that mass increases with Speed(Kinetic Energy)
EDIT:Look at the Equation given by Enigman.
quawa99
#9
Nov26-13, 11:20 AM
P: 63
So bottom line velocity of light and charge are the two physical quantities which aren't relative ?
Hertz
#10
Nov26-13, 11:21 AM
P: 149
Quote Quote by adjacent View Post
I hate arguing anything that I'm not too confident in, but for the sake of education!:
I learned relativistic kinetic energy as:
[itex]T=(\gamma_u - 1)mc^2[/itex] where mass is absolute. This is from the book "Modern Physics" second edition by Randy Harris
Also, total relativistic energy:
[itex]E=\gamma_u mc^2[/itex]. Where mass is absolute.
edit-
There are most certainly other quantities as well..
quawa99
#11
Nov26-13, 11:25 AM
P: 63
Isn't charge relative because electric and magnetic feilds are relative?
WannabeNewton
#12
Nov26-13, 11:28 AM
C. Spirit
Sci Advisor
Thanks
WannabeNewton's Avatar
P: 5,637
No charge is a Lorentz invariant. This follows from local charge conservation which is itself a consequence of Maxwell's equations.
Rest mass (more appropriately called invariant mass) is also a Lorentz invariant.
Enigman
#13
Nov26-13, 11:31 AM
Best Humor
Enigman's Avatar
P: 560
Perhaps you are talking about the rest mass or the invariant mass? This the mass observed in an inertial frame where the object in question is at rest. (I perhaps should have mentioned this before)
gives the mass as observed from a frame in which object in question is moving with velocity v.
But often mass and rest mass are used interchangeably
Derivation here- http://www.scribd.com/doc/98591006/S...ativistic-Mass.
(WBN beat me to it...)
Nugatory
#14
Nov26-13, 11:36 AM
Sci Advisor
Thanks
P: 3,757
The quantity ##M## in that equation is not frame-invariant, but ##M_0## is. It's something of a matter of taste which one you consider to be "mass", and that taste has changed over the years.
Enigman
#15
Nov26-13, 11:52 AM
Best Humor
Enigman's Avatar
P: 560
Quote Quote by Nugatory View Post
Yes, I was talking about relative or 'observed mass' as I thought it would be obvious from the context and not rest mass which is by definition frame-invariant.
This is of course correct, provided m represents relative mass. And as ##m_{rel}=\gamma m##
The mass-energy equation reduces to ##E=m_{rel} c^2##.
##m_{rel}## is the mass that would be observed from a frame in which the object moves with velocity v and m is the mass in the frame in which relative velocity is zero.
You may want to read-
ZapperZ
#16
Nov26-13, 11:57 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Y'know, the more things change, the more they remain the same. This thing keeps coming back like an unwanted guest.
http://www.physicsforums.com/showthread.php?t=642188
Please note this FACT: when you read the mass values of the various particles in the Particle Data Book, you'll notice that they never cite the corresponding speed. If mass is "relative", then there will not be a unique, unambiguous value.
Zz.
Hertz
#17
Nov26-13, 12:02 PM
P: 149
Zz.
Thanks for this link. This person has some very interesting points :)
ZapperZ
#18
Nov26-13, 12:05 PM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
If by "this person" you meant Lev Okun, he is on this forum:
http://www.physicsforums.com/showthread.php?t=696144
Zz.
Register to reply
Related Discussions
Relative Permitttivity & Relative Permeability Dependency General Physics 4
Relative speed, relative angles Introductory Physics Homework 1
Relative Length to Relative Volume Special & General Relativity 1
Relative velocity=relative momentum? Special & General Relativity 1
X' relative to S' and relative to S Special & General Relativity 6
