Register to reply
An electromagnetic question.
Share this thread:
clark84
#1
Nov26-13, 02:52 PM
P: 3
What are the three forces responsible for a neodymium magnet to fall slowly down through a heavy copper tube?
Phys.Org News Partner Physics news on Phys.org
Vibrational motion of a single molecule measured in real time
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Bubbling down: Discovery suggests surprising uses for common bubbles
Simon Bridge
#2
Nov26-13, 03:38 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,765
Welcome to PF;
That's a good question - what have you come up with so far?
i.e. have you listed the forces that are available to the universe? There are only four - but I feel the question may be treating one of them as two.
davenn
#3
Nov26-13, 03:55 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,597
Hi clark
its a good experiment, as Simon has said, have a think about what is happening
A hint ... a moving magnetic field and a conductor
also it could be any magnet and it works just as well with an aluminium tube
I use this action to produce dampening in a seismometer ( earthquake detector)
but rather than an aluminium tube, I use a moving strip of aluminium between 2 fixed magnets
Dave
clark84
#4
Nov26-13, 07:18 PM
P: 3
Quote Quote by Simon Bridge View Post
Welcome to PF;
Well I can think of the two obvious, Gravity and Electromagnetic force.
Simon Bridge
#5
Nov27-13, 01:42 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,765
1. gravitation
2. electrical
3. magnetic
ruling out the strong and weak nuclear forces.
But - it may be that the question is thinking in terms of a free body diagram?
It really depends on where you are up to in your course.
Have you tried davenn's suggestion?
clark84
#6
Nov27-13, 11:44 AM
P: 3
Quote Quote by davenn View Post
Hi clark
Dave
I know that an electric current is generated when the magnet moves through the conductor. I looked it up and found something called "Eddy's Current" that i will need to look into so i can better understand exactly what occurs.
davenn
#7
Nov27-13, 02:47 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,597
Quote Quote by clark84 View Post
I know that an electric current is generated when the magnetic field moves through the conductor. I looked it up and found something called "Eddy's Current" that i will need to look into so i can better understand exactly what occurs.
That's a good start
Now think or research about what those eddy currents that are set up in the pipe do/cause
Dave
PS, note the little highlighted correction I did in your quoted text
Register to reply
Related Discussions
Electromagnetic force question General Physics 2
Question regarding electromagnetic interaction Classical Physics 4
Question about Electromagnetic Energy Classical Physics 3
Electromagnetic question Introductory Physics Homework 2
Another Electromagnetic Induction Question Introductory Physics Homework 1
