Register to reply
P-n junction
by daudaudaudau
Tags: junction
Share this thread:
daudaudaudau
#1
Nov27-13, 12:15 PM
P: 296
Hello.
I have a question regarding the p-n junction. When I look at figure B here:
http://en.wikipedia.org/wiki/P-n_junction
it looks completely wrong to me. Take the E-field. It is going to be positive outside the depletion region, which in turn will make the voltage tend towards zero for x→∞. Right ??
Phys.Org News Partner Physics news on Phys.org
Technique simplifies the creation of high-tech crystals
Working group explores the 'frustration' of spin glasses
New analysis of oxide glass structures could guide the forecasting of melt formation in planetary interiors
mfb
#2
Nov27-13, 04:08 PM
Mentor
P: 11,601
The figure looks good.
Quote Quote by daudaudaudau View Post
No.
(explain more what you don't understand to get more specific answers)
daudaudaudau
#3
Nov28-13, 02:27 AM
P: 296
Quote Quote by mfb View Post
No.
Well the depletion region is a dipole, isn't it? So the e-field will look like this
http://hyperphysics.phy-astr.gsu.edu...gele/edip2.gif
So if the field is negative "inside" the dipole, it is positive outside (but of small magnitude, of course).
mfb
#4
Nov29-13, 07:46 AM
Mentor
P: 11,601
P-n junction
It is not, you have two "infinite" sheets, and infinite sheets have a constant field around them - two sheets with opposite charge of the same magnitude lead to fields that cancel everywhere outside.
daudaudaudau
#5
Nov29-13, 11:07 AM
P: 296
Well, clearly the depletion region is not infinite in extent. Also, the field is not constant in the figure that you said looks good.
mfb
#6
Nov29-13, 11:17 AM
Mentor
P: 11,601
That is a very good approximation for most transistors.
The field is zero outside the regions with net charge, so the potential is constant. The field is not constant in the region with net charge, as there is net charge on the sides.
Register to reply
Related Discussions
Flow of gas in a t-junction with one junction sealed. General Engineering 9
Transistors-Why can't a pn junction and np junction in series be a pnp transistor? Atomic, Solid State, Comp. Physics 3
PN junction Advanced Physics Homework 0
Pn junction Introductory Physics Homework 2
P-n junction Classical Physics 6
