proton magnetic moment flip angle 54.7 in an external magnetic field
by mkj
Tags: angle, field, flip, magnetic, magnetic moment, moment, precession, proton
mkj
mkj is offline
#1
Nov27-13, 03:39 PM
P: 5
i am reading about MRI. i have seen several in several textbooks that the angle between the direction of the proton magnetic moment μ and the direction of the external magnetic field is 54.7
how did they find that theoretical or experimental
if theoretical how can we calculate that
Phys.Org News Partner Physics news on Phys.org
Modification of structural composite materials to create tailored lenses
Novel technique opens door to better solar cells
Probing metal solidification nondestructively
tiny-tim
tiny-tim is offline
#2
Nov27-13, 04:21 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
hi mkj!
loosely speaking, the angular momentum P is fixed
if there's no magnetic field, there's no problem the "spin axis" can be in any direction
if there is a magnetic field in the z direction, the component Pz is quantised, and (for a spin-half particle) must be P/√3
so the angle between P and z must be cos-11/√3, = 54.74
(see eg http://www.chem.wisc.edu/areas/reich...hmr-00-nmr.htm)
Register to reply
Related Discussions
Magnetic moment due to applied external magnetic field Advanced Physics Homework 2
Tricky Magnetic Field Question... (Proton Enters Magnetic Field......) Introductory Physics Homework 8
Why does the magnetic moment of a nucleon line up with a uniform magnetic field? Classical Physics 1
Alignment of micro dipoles in magnetic material in external magnetic field. Classical Physics 5
Magnetic dipole in an external magnetic field General Physics 3
