Why is the zenith angle distribution of the muons cos2(x) ?
by phys_student1
Tags: angle, cos2x, distribution, muons, zenith
phys_student1
phys_student1 is offline
#1
Nov27-13, 08:42 PM
P: 88
Hello,
Empirically, the flux distribution of cosmic ray muons follow cos^2(θ) where θ is angle of incidence. Looking up the papers, I did not find any clue as to why is this the case. All sources simply consider this an experimental fact.
Is their any real explanation for this?
Phys.Org News Partner Physics news on Phys.org
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Mapping the road to quantum gravity
Chameleon crystals could enable active camouflage (w/ video)
mfb
mfb is offline
#2
Nov29-13, 09:06 AM
Mentor
P: 10,854
That is a common question and I never saw a good answer. It is probably just some function which is not so far away from the real distribution, without a deeper physical argument behind it.
atha
atha is offline
#3
Nov30-13, 10:29 AM
P: 7
First of all consider that the earth's atmosphere is a perfect sphere.
The path length for θ=0 is the minimum possible.
Also note that there no chance to detect a muon for θ=π/2(for this specific angle the muon would have to travel along the earth's crust, it would collide and interact with the crust's atoms with a very high probability).
Those arguments state that we need a cos-like distribution.
The next step is to think that the muon obeys the Bethe-Bloch formula. In simple words the energy loss per unit length, is something like 1/β^2...
This implies that it is very much likely to observe a muon for small θ(where the path length is minimum) rather that large θ, in a non-linear way.
If you also put in mind that the earth's atmosphere isn't a perfect sphere, but it's a "3D ellipsoidal", you are again moving away from linearity.
I believe that Andersson has done some "fitting" on experimental data of cosmic ray flux, which proves the cos^2θ distribution.
So it is an experimental model, as far as I know.
Vanadium 50
Vanadium 50 is offline
#4
Nov30-13, 11:14 AM
Mentor
Vanadium 50's Avatar
P: 15,625
This is an approximation, and as such, you won't be able to derive it.
If cosmic rays were uniform and isotropic, you'd expect a distribution that goes more like 1/cos(theta), because there's not a lot of area with a small zenith angle compared to a large one. However, as atha points out, we have an atmosphere, so cosmic rays from the horizon are unlikely to make it to us.
phys_student1
#5
Nov30-13, 02:24 PM
P: 88
Thanks all. Yes I also looked too much in the literature without finding any clue, all state is as empirical formula or experimental fact. Thanks for your responses.
Register to reply
Related Discussions
Laplace transform of cos2(t-1/8π), help? Calculus & Beyond Homework 2
Angle pd decay between two muons between Z boson? High Energy, Nuclear, Particle Physics 3
Zenith Angle of Moon Terminator? General Astronomy 0
Atmosphere as a function of Zenith angle? Introductory Physics Homework 3
How do I put a Zenith Angle in my calculator? Introductory Physics Homework 3
