Calculating Wavelength of Light in Glass Slab
  • Thread starter Thread starter sghaussi
    Light Propagation
The discussion focuses on calculating the wavelength of light in a glass slab, given specific parameters. Light with a wavelength of 560 nm travels through air in 16.5 ns and through a 0.860 m glass slab in 21.3 ns. The speed of light in a vacuum is stated as 3×108 m/s. Key calculations involve determining the distance traveled in air and glass, which leads to finding the speed of light in glass and subsequently the wavelength in the medium.
  • Understanding of light propagation and wavelength
  • Familiarity with the concept of refractive index
  • Basic knowledge of time-distance-speed relationships
  • Ability to perform calculations involving nanoseconds and meters
  • Calculate the refractive index of glass using the formula n = c/vglass
  • Learn how to derive wavelength in different media using the formula λ = λ0/n
  • Explore the impact of medium thickness on light speed and wavelength
  • Study the principles of light refraction and Snell's Law
Physics students, optical engineers, and anyone interested in understanding light behavior in different media.
sghaussi
Hi! I was wondering if you can give me some adivice on how to approach this problem:
In a physics lab, light with a wavelength of 560 nm travels in air from a laser to a photocell in a time of 16.5 ns. When a slab of glass with a thickness of 0.860 m is placed in the light beam, with the beam incident along the normal to the parallel faces of the slab, it takes the light a time of 21.3 ns to travel from the laser to the photocell.
What is the wavelength of the light in the glass?
Use 3×108 m/s for the speed of light in a vacuum.
My main problem is that I don't know how the thickness of the medium is important.
Thank you in advance,
Sahar
how long did the light take to travel the glass?
thats when the thickness counts
you can get your index once you figure this out
as the light goes through the glass, the frequency doesn't change just the wavelength
what does this tell you?
The first thing to do is to find how long the original path is.
[tex]s_0 = c\Delta t_0[/tex]
For the path through the glass, there are two parts:
[tex]s_{air} = c\Delta t_{air}[/tex] and
[tex]s_{glass} = v_{glass}\Delta t_{glass}[/tex]
so you know, or can work out: [itex]s_{air},\Delta t_{air}, s_{glass}, \Delta t_{glass}[/itex]
From that you should be able to work out [itex]v_{glass}[/itex] and wavelength follows from that.
AM
