Register to reply
Dividing cancels out a solution?
by ainster31
Tags: cancels, dividing, solution
Share this thread:
ainster31
#1
Dec4-13, 10:01 AM
P: 154
Context: https://www.youtube.com/watch?v=sQM-8Oj4Ecg
In the video, he divides out a variable as below:
$$r^2=2rsin\theta\\r=2sin\theta$$
When you do a division like this, aren't you dividing out a variable?
What happens if you take the square root of both sides like below?
$$r^2=2rsin\theta\\|r|=\sqrt{2rsin\theta}$$
Would that be more correct?
Phys.Org News Partner Mathematics news on Phys.org
'Moral victories' might spare you from losing again
Fair cake cutting gets its own algorithm
Effort to model Facebook yields key to famous math problem (and a prize)
HallsofIvy
#2
Dec4-13, 10:06 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,345
Yes, he is. I particular, he has "lost" the r= 0 for all [itex]\theta[/itex] solution.
I'm not sure what you mean by "more correct" for [itex]|r|= \sqrt{2r sin(\theta)}[/itex]. It is not at all a "solution" because you have not "solved for r".
Mark44
#3
Dec4-13, 10:07 AM
Mentor
P: 21,215
Quote Quote by ainster31 View Post
Well, of course. The more important point is that you are potentially losing a solution of the equation; namely, r = 0. In this case, it doesn't matter because the equation r = 2sin(θ) still has r = 0 when θ = 0 + k##\pi##.
No, and besides, what's the point? You haven't solved for r since it still appears on both sides of the equation.
ainster31
#4
Dec4-13, 10:10 AM
P: 154
How did you know he cancels out the ##r=0## solution?
Nugatory
#5
Dec4-13, 02:08 PM
Sci Advisor
Thanks
P: 3,458
Because that's the solution that always disappears when you divide by a variable. The only root of ##rA(...) = rB(...)## with ##A\neq{B}## is ##r=0##, and that's the one that we're losing when we divide both sides by ##r## to turn the equation into ##A(...) = B(...)##.
Office_Shredder
#6
Dec4-13, 02:54 PM
Emeritus
Sci Advisor
PF Gold
P: 4,500
Any time you divide both sides of an expression by something, you should check to see whether that thing can be zero. If it can be, then you have lost solutions corresponding to when that equals zero. For example, if someone asks you to solve:
(x-1)(x-2) = (x-1)(2x-1)
The first thing we do is divide both sides by x-1
(x-2) = (2x-1)
Now we solve for x
x = -1
OK, but we divided both sides by x-1, and we have to be worried about when that is equal to zero. x-1= 0 when x=1, so I should go back to the original equation and check that x=1 is a solution, which it is easily seen to be.
Jarfi
#7
Dec4-13, 05:28 PM
P: 269
Simply do:
r^2=2rsin\theta\ <-> r(r-2sin\theta\)=0 <-> r = 0 or r = 2sin\theta\
problem solved !
(sorry I dont know how to do the maths letters here )
Register to reply
Related Discussions
Point where magnetic field cancels between two current carrying wires. Introductory Physics Homework 7
NASA cancels Laser Interferometer Space Antenna Astronomy & Astrophysics 5
Earthward Upper Stratospheric IR Radiation Cancels Most Greenhouse Gas Effect Earth 9
Clinton cancels commencement speech General Discussion 24
When gravity cancels out General Physics 42
