What does it mean to 'drive' a coil?
In summary, the conversation discussed the use of AC current in an inductor coil to create a magnetic field and how this process is used in speakers to produce sound. The speaker coil is driven by the audio signal, causing the speaker membrane to vibrate and produce sound waves. The term "drive" is commonly used in engineering to describe the process of supplying energy to a device. It was also mentioned that the voicecoil is typically the moving part in a speaker, rather than the magnet attached to the cone.
JustStudying
27
I hear this term a lot but couldn't find much from a google search
My initial guess is that we put a AC current through a inductor coil to create a magnetic field.
Am I close?
your audio signal is amplified and run through the speaker coil "driving" it to move the speaker membrane back and forth crating vibrations in the air which reach your ear vibrating the typanum and other parts and thus producing the sound your hear.
http://www.physics.org/article-questions.asp?id=54
http://en.wikipedia.org/wiki/Eardrum
So yes the audio signal induces a varying magnetic field that causes the magnet attached to the speaker membrane to move back and forth.
I don't think it is typical for the magnet to be attached to the cone (speaker membrane if you like). The voicecoil is a much lighter part of the assembly. Logically for high frequency response, this would be the part you would engineer as the moving part.
This is just about use of words in a particular context. The OP didn't specify a speaker coil. The term 'drive' is just a general engineering term which means to feed anything with energy. You can 'drive' an LED or Data display of some sort, a relay coil, the output stage of an RF or Audio amplifier. The term is often used when the power level is increased above what would be regarded as signal level.
@JustStudying. I suspect that you are new to the field of EE and there will be a lot of terms that turn up for you which are not formally defined but which are commonly used. This is the same as in many other fields - Sport, Computing, Music etc.. Get immersed in the topic by reading all sorts of stuff and they will begin to mean something. If in doubt and if you can't Google a meaning then get a clue from the context. If you stick to proper textbooks, you will encounter less jargon but miss out on the 'flavour' of the subject.
Yes, you are close. 'Driving' a coil refers to the process of applying an alternating current to an inductor coil to create a varying magnetic field. This magnetic field can then be used for various purposes such as inducing an electric current in nearby conductive materials or creating a force on other magnetic objects. This process is commonly used in devices such as motors, generators, and transformers. Additionally, the frequency and amplitude of the alternating current can be adjusted to control the strength and direction of the magnetic field, making it a versatile tool in many scientific and technological applications.
1. What is a coil?
A coil is an electrical component that is made up of a series of loops or turns of wire. When an electric current flows through the coil, it creates a magnetic field.
2. How do you drive a coil?
To drive a coil means to apply an electric current to it. This can be done using a battery or power source connected to the ends of the coil.
3. What is the purpose of driving a coil?
Driving a coil allows the magnetic field created by the coil to interact with other magnetic fields, such as those created by other coils or permanent magnets. This interaction can be used in a variety of applications, such as motors, generators, and electronic devices.
4. Can you drive a coil with AC or DC current?
Yes, a coil can be driven with both AC (alternating current) and DC (direct current). The type of current used will depend on the specific application and the desired effect on the coil's magnetic field.
5. What factors affect the strength of a coil's magnetic field when driven?
The strength of a coil's magnetic field when driven is affected by the number of turns in the coil, the amount of current flowing through the coil, and the type of core material used in the coil. Additionally, the distance between the coil and other magnetic fields can also impact the strength of the field.
  • Other Physics Topics
21K
  • Electromagnetism
  • DIY Projects
  • Electromagnetism
  • Electromagnetism
