Contraviant and covariant tensor
  • Context: Graduate
  • Thread starter Thread starter jby
    Covariant Tensor
The discussion revolves around the concepts of contravariant and covariant tensors, exploring their definitions, implications, and the terminology associated with them. Participants express concerns about the accessibility of these concepts in introductory materials, as well as share resources and personal sentiments regarding the terminology used in the field.
  • Homework-related
  • Some participants express that introductory texts often start with contravariant and covariant tensors, which they find misleading.
  • One participant suggests that the terms "covariant" and "contravariant" are more descriptive and helpful than the term "tensor," which they find misleading.
  • A participant describes a mapping from one space to another, explaining how covariant and contravariant entities behave under such mappings.
  • Another participant questions whether one can compare a contravariant entity at one point with a covariant entity at another, suggesting this would be contrary to the mapping.
  • Several participants share book recommendations and online resources for learning about relativity and tensors, with varying opinions on the quality and reliability of these resources.
  • Concerns are raised about the credibility of certain online notes, with warnings about the author's past behavior and the accuracy of their content.
  • Some participants note that while certain parts of the online notes may be acceptable, others contain significant errors, particularly in the definitions and derivations related to force and acceleration.
Participants do not reach a consensus on the appropriateness of the terminology used in relation to tensors, nor do they agree on the reliability of the online resources mentioned. The discussion remains unresolved regarding the best approach to understanding these concepts.
There are limitations in the discussion regarding the definitions of covariant and contravariant tensors, as well as the implications of the terminology used. Some participants express differing views on the accuracy of certain educational resources, and there are unresolved issues concerning the mathematical definitions and derivations presented.
This discussion may be of interest to students and educators in physics and mathematics, particularly those seeking to understand the concepts of tensors and their applications in relativity.
jby
Any books recommended for dummies? All books that I've found starts with contraviant and covariant tensor, which seems misleading to me.
Let me guess. You looked at "Shaum College Outline Series" inexpensive good book with lots of worked problems----nothing wrong with book, you were just put off by words "contravariant and covariant". Problem is not with book or with you but with ice-cold nomenclature.
cant help with other book-recommendation---surely others will
So I will take a bizarre attitude and attempt to persuade you that the words covariant and contravariant are actually warm and fuzzy. they are your friends and the really bad terminology in that bunch is "tensor"
my private sentiment is that the word "tensor" is misleading
(probably "dingus" would do as well and it is just some
historical accident that they started saying tensor-----but covar
and contravar are descriptive names, therefore could be helpful to understand what they mean.
are you all right with the idea of a smooth mapping from some place to another place?
(how you think of the "places" depends on the problem, or on mathematical habit and convention, they might be the surfaces of two different potatos or even two copies of the same potato)
a covariant dingus is something that the mapping carries along with it from place X to place Y
a contravariant dingus is something that a mapping from X to Y "pulls back" from Y to X, so it gets translated opposite or contrary to the direction of the mapping
Let's write f: X --> Y to mean a map from X to Y
some gizmos (functions, calculus tools, mathematical contraptions) that you can define on Y are of a sort that f pulls back in a natural way to wherever it is defined, namely to X.
other bits of hardware are of a sort that if they are defined on Y the map will not pull them back but if they are defined on X the map will carry them over and make versions of them defined on Y,
directional derivatives work that way.
for example a plain old real valued function G(y) defined on Y will pull back, using the map f,
to become a new function G(f(x)) defined on X
but a real-valued function G(x) defined on X will not push forward to a function defined on Y----the mapping f:X-->Y is going the "wrong way" to accomplish that, you would need to have an inverse map of f and that is not always defined or available.
however a trajectory or path in X is COvariant because the map f will transform it into an image path in Y. And taking the derivative of some real-valued function defined on X at a point along that path translates into taking the derivative of a function defined on Y along the image path.
so the solemn ritual of taking a derivative of whatever and in whatever direction goes along WITH the map, getting carried along from X to Y in the same direction as the map goes.
in the end one just has to draw pictures. the two potatoes and the arrow going from one to another, and think about the chain rule of ordinary freshman calculus (nothing ever gets done without applying the chain rule at some point)
Dingus it is then! I've always hated the term "tensor." Great explanation too. I'll be using it later this year if you don't mind. (And even if you did, how would you stop me?)
Can I take a dingus at Y and carry it back to X and compare it with the dingus at X and take the derivative? That'd be like going CONTRARY to the mapping and hence CONTRAvariant, isn't it?
Originally posted by jcsd
While your here, i found these on-line notes on 'Modern Relativity' extermely useful as a refernce work whilst working on the computer:
http://www.geocities.com/zcphysicsms/
Use caution when using these notes. They were written by a well known crackpot. Most of it is okay I guess (simple stuff copied from texts) but other parts are very wrong.
The author used to post here for a short time. He came here and imediately started flaming me when he couldn't convince me that a scalar was not defined in modern physics/math as a tensor of rank zero. He was banished when he started to flame the moderator. He was warned to cease flaming but continued and was tossed out.
Pete
What do you find misleading about this? Covariant/contravariant refer to the geometric object in most cases (sometimes it refers to a vector and its dual)
If you'd like more on covariant vs. contravariant see
http://www.geocities.com/physics_world/co_vs_contra.htm
Pete
Pete
I haven't looked over all of them, but they do seem okay to me, I've the feeling he might of lifted them from a textbook.
Some but not all.
For instance: The author keeps trying to define force as mass times acceleration. That has always gotten him into trouble in the past and I'm sure it will in the future too. In this particular case he tried to derive an expression for the Coriolis force. So he derived an expression for the Coriolis acceleration and then multiplied it times rest mass and calls that the "Coriolis force." His result is incorrect for that reason. His bogus derivation of the Coriolis force is here
http://www.geocities.com/zcphysicsms/chap6.htm#BM80
For a correct derivation see
http://arcturus.mit.edu/8.962/notes/gr6.pdf
Force is defined as the time rate of change of momentum - not as mass times acceleration. Bertschinger gets it right. The author of that website you referanced was shown this and all he could do was his usual backpeddling - It was too silly of response to repeat here. For those interested go to sci.physics.relativity and read the thread "Centrifugal etc fict-force relativistic derivation"
Then there is the subject regarding tidal forces. He botches that up pretty bad. He does something bizarre - he defines tidal force differently than the rest of the world and then proceeds to show that there is no such thing as a gravitational tidal force. He tries to define tidal force in terms of 4-forces which is quite unlike the term is defined in General Relativity. His definition is that the tidal force is the gradient of a 4-force of a particle in free-fall which is total nonsense since the gravitational force is an inertial force and not a 4-force. Any decent GRist knows that as fact.
Then there is the time where he was totally unable to comphrend what a tidal force tensor was or how it is related to the Riemann tensor.
See - http://www.geocities.com/physics_world/tidal_force_tensor.htm
for the Newtonian definition. The GR definition is that the tidal force tensor is the Riemann tensor. They're related.
Then there is the part where he claims that by "curvature" cosmologists mean "Gaussian curvature" which is bogus as well.
Then there is his claim that a uniform gravitational field has spacetime curvature when its really defined as having no tidal forces.
Pete
It goes on and on and on. He's just a crackpot - plain and simple.
Do me a favor and let's stop that line of discussion here and get back to the original question. Thanks.
  • · Replies 26 ·
  • · Replies 25 ·
