How can I combine the solutions for u(t) and y(t) to find the solution for y(t)?
The discussion revolves around solving a second-order ordinary differential equation (ODE) of the form y'' = f(t, y) using numerical methods. Participants explore how to combine the solutions for y' and y to derive y(t) from the numerical outputs of their computations.
  • Homework-related
  • One participant introduces the substitution u = y' to transform the second-order ODE into a system of first-order ODEs, leading to u' = f(t, y) and y' = u.
  • Another participant suggests using numerical methods like Runge-Kutta to solve the resulting first-order equations, emphasizing the need for initial conditions y(a) and v(a).
  • Concerns are raised about the definition of v(x) and how to apply numerical methods without knowing v(x) explicitly.
  • Participants clarify that v(x) is simply y'(x) and that both y(x) and v(x) must be calculated simultaneously during the numerical integration process.
  • There is a discussion about the necessity of providing a function for the ODE solver and the implications of not having a clear definition for v(x).
  • One participant proposes a step-by-step approach to solving the system, outlining the need to calculate both y(x) and v(x) at each step of the numerical method.
Participants generally agree on the method of using numerical techniques to solve the ODEs, but there is some confusion regarding the role and definition of v(x) and how to implement the numerical methods effectively. The discussion remains somewhat unresolved regarding the clarity of the function needed for the ODE solver.
Participants express uncertainty about the specific form of the function f(t, y) and how it relates to the numerical methods being discussed. There are also mentions of initial conditions and their importance in obtaining a unique solution, but the exact requirements for the function remain unclear.
eckiller
Suppose we have y'' = f(t, y); y(a) = y0; y'(a) = y0'
Note all derivatives are with respect to t.
Let u = y', then u' = y''
1. u' = f(t, y), u(a) = y'(a)
2. y' = u, y(a) = y0
Question 1: For y' = u, should I think of this as dy/du = u? Otherwise, I don't see how to solve 2 because what is u as a function of t?
So I pump both (1) and (2) through a numerical ODE solver.
For (1) I get answer u(t), and for (2) I get answer y(t) ? That doesn't seem right, as y(t) is what I want. How do I put my two answers together to get y(t).
As you can probably tell, I'm very confused on this.
So for:
[tex]y^{''}=f(x,y)[/tex]
Let:
[tex]y^{'}=v(x)[/tex]
[tex]v^{'}=f(x,y)[/tex]
Now you have two first-order ODEs just right for Runge-Kutta or other methods. To start the numerical method, y(a)=[itex]y_0[/itex] and v(a)=y'(a).
When you get the results, you get two separate (numerical) functions: y(x) and v(x). y(x) is the solution of the original second order ODE. v(x) is just y'(x) expressed as another function.
So for:
y'' = f(x, y)
Let:
y' = v(x)
v' = f(x, y)
Now you have two first-order ODEs just right for Runge-Kutta or other methods. To start the numerical method, y(a)=y0. Reload this page in a moment. and v(a)=y'(a).
Thank you for your reply. Okay, up to this point I don't know what v(x) is in y'. I don't see how I can apply Runge-Kutta to y' = v(x) if I do not know v(x) !
v(x) is y'(x). Now, since you're using Runge-Kutta, you know the first data points right? You know y(a) and y'(a)=v(a). Runge-Kutta then calculates the second data points: y(deltax) and v(deltax), and so forth. You then end up with 2 functions. y(x) is the solution and v(x) is just . . . well extra.
Forgive me. This is probably something obviously simple I am missing.
y'(x) = v(x).
But I am not given what y' is. I am given y'' = f(t, y).
For example, to a numerical ODE solver, we supply the g function,
dy/dt = g(t, y),
as a parameter to the ODE solver. So I don't get what I am to supply because I don't know what v(x) is or dy/dt. Are you saying it is just:
y'(x) = v
where v is just linear? Almost as in y'(x) = t ? If so why not just integrate directly then?
y'(x) = v(x).
dy/dt = g(t, y),
y'(x) = v
Alright, I'm sorry you're having problems with my explanation. You know that for a second order ODE to have a "unique" solution, you MUST be give two conditions. Usually these are "initial conditions" in the form of y(0)=a and y'(0)=b. You need to have these values supplied in order to work the Runge-Kutta method. Your first post, as I interpreted it, indicated that you are given these two values.
I tell you what, even if you're not given them, try using just any values say y(0)=1 and y'(0)=0 or whatever and do the numeric analysis just to verify you have the algorithm down correctly.
You said:
"For example, to a numerical ODE solver, we supply the g function,
dy/dt = g(t, y)"
Well, even that you still need to supply an initial condition in the form (usually) of y(0)=a.
Yes I am given the initial conditions. But I still need the function. For simplicity, the Euler step:
slope = feval(funcHandle, t(i-1), y(i-1));
y(i) = y(i-1) + slope*step;
where funcHandle is the f(t, y) in y' = f(t, y).
I think I see the problem now: You need to calculate Runge-Kutta for BOTH y(x) AND v(x) simultaneously. You're given the starting points, then run through one delta x, calculate y(x) AND v(x) at that point, go to the next step, calculate both again, and so forth. It's a little messy.
Okay so going back to y'' = f(t, y)
Step each step:
(a) Solve v' = f(t, y) for this step
(b) Use solution from (a) to solve y' = v
Is that right?
Step each step:
Is that right?
Ok, so we have:
Calculate y(x1) and v(x1). You can do this because you have their derivatives there and the initial conditions y(0) and v(0). The next step, x2, you do that all over, calculate y(x2) AND v(x2) at the same time. You can do that since again, you know what the slopes are and what the previously calculated values were. Then do y(x3) AND v(x3) and so forth. You'll think it's easy once you do a few. Hope that helps. Gotta check out . . .
I see now. Thank you.
  • · Replies 0 ·
