Measuring Ocean Waves for Wave Energy Projects
In summary, the person is looking for a device to measure the wave height and wants to know what kind of device would be accurate and deep enough to measure the waves.
simpsonocean
Halo everyone. I am new to here!
I am working with a project of ocean wave energy.
I would like have a device that can measure the wave length, pitch those wave parameter when I testing my wave energy device.
Anyone have a clue what kind of device can complete my task?
How deep is the water where you doing your tests?
How big might the waves be?
How accurate do you need the measurements to be?
I would consider a bottom mounted, up-looking, sonar depth sounder that generates a continuous signal that can be sent to shore along the power cable. By logging that data during the experiment you will have data for an amplitude and wavelength analysis by using an FFT. It will resolve several different wave sources with different wavelengths. If you had doppler you could also measure the circulation velocity of the wave movement.
The location should be about 150m away from coast.
-It will about 5-10m deep.
I won't be mega wave in pacific ocean..lol ..
-It should be up to 2m.
-The accuracy is around +-10cm
simpsonocean, Welcome to Physics Forums!
This Wiki page gives a good introduction to the subject and useful information plus references:
http://en.wikipedia.org/wiki/Wave_height
See this from the United States Army Corps of Engineers' Coastal and Hydraulics Laboratory, the Coastal Engineering Manual (CEM) ,Part II, Chapter 1:
http://140.194.76.129/publications/eng-manuals/EM_1110-2-1100_vol/PartII/Part_II-Chap_1.pdf
Here are two paragraphs from the University of California, San Diego that describe types of sensors:
“There are two main types of sensors used to measure sea surface elevation, pressure sensors and buoys. Pressure sensors are mounted at a fixed position underwater, and they measure the height of the water column that passes above them. As wave crests pass by, the height of the water column increases; when troughs approach, the water column height falls. By deducting the depth of the sensor from the water column heights, a record of sea surface elevations can be generated.”
“Buoys ride atop the surface of the ocean. Equipped with accelerometers to record their own movements, buoys rise with the wave crests and fall with the troughs. Since buoys are always floating on the sea surface, by recording their own movements they are in fact recording the movements of the sea surface. Readings from the accelerometers inside the buoys can be used to calculate the buoys' vertical displacements; these values are also a record of sea surface elevation.”
http://cdip.ucsd.edu/?sub=index&nav=documents&xitem=waves
Wave height measurement techniques from Texas A&M University:
http://oceanworld.tamu.edu/resources/ocng_textbook/chapter16/chapter16_06.htm
Here are four manufacturers that sell wave sensors:
http://www.oconnerengineering.com/Marine/wave_height.htm
http://www.nickbelsondesign.co.uk/wave_height_sensors.HTM
http://www.oceanor.com/systems/seawatch/buoys-and-sensor/
http://www.falmouth.com/sensors/tidewavemeters.html
A do-it-yourself wave height sensor project using a tantalum wire: http://journals.ametsoc.org/doi/pdf/10.1175/1520-0426(1995)012<0190:ANWHS>2.0.CO;2
There are also capacitive sensors. You may use Google search to find details about them.
Welcome to the community! I can offer some suggestions for measuring ocean waves for wave energy projects. There are several devices that can be used to measure wave parameters such as wave length and pitch. Some common options include wave buoys, wave radars, and wave gauges. Each of these devices has its own advantages and limitations, so it is important to carefully consider your project's specific needs before selecting a device. Additionally, it may be helpful to consult with experts in the field of wave energy to determine the most appropriate device for your project. I wish you the best of luck with your research and project!
1. What are ocean waves and how are they measured?
Ocean waves are the rhythmic movements of the ocean's surface caused by wind, currents, and other forces. They are measured using a variety of instruments including buoys, satellites, and wave measurement devices.
2. Why is it important to measure ocean waves for wave energy projects?
Measuring ocean waves is crucial for wave energy projects because it helps determine the potential energy that can be harnessed, as well as the most suitable location for the project. It also allows for the design and optimization of wave energy devices.
3. What are the different methods used to measure ocean waves?
The most common methods to measure ocean waves include using wave buoys, satellite altimetry, and wave measurement devices such as wave radars or laser sensors. These methods provide different types of data, such as wave height, period, and direction.
4. How accurate are ocean wave measurements?
The accuracy of ocean wave measurements depends on the method used and the location of the measurement. Generally, satellite measurements have a higher accuracy compared to buoy or device measurements. However, all methods have a margin of error, and it is important to calibrate and validate the data for accuracy.
5. Can ocean waves be measured in real-time?
Yes, ocean waves can be measured in real-time using advanced technologies such as satellite altimetry and wave measurement devices. This allows for a continuous monitoring of wave conditions, which is essential for wave energy projects to optimize energy production and ensure safety.
  • Quantum Physics
  • Other Physics Topics
  • Quantum Interpretations and Foundations
  • Quantum Physics
