Register to reply
Number of combinations with limited repetition
Share this thread:
EmileMaras
#1
Dec12-13, 06:00 AM
P: 2
Hello
I have the following combinatoric problem :
I want to distribute n (equivalent) atoms among M distinct objects. Each object can contain from 0 to nlim atoms. How many combination do I have for this system?
If nlim>n, this problem actually corresponds to the classical "Number of combinations with repetition". But in my case nlim<n. In fact, I am interested in the limit of (lnΩ)/n (Ω beeing the number of combination) when M and n tend toward infinity (with n=a M where a is a constant) while nlim is finite (and actually rather small)..
I found a solution for that problem using some series of summations but it will be impossible to caculate as soon as M and n become large (even for M=100, n=300 and nmax=10, it took my laptop more than one hour to solve it).
Is there a simple analytical solution to this problem?
Thank you for your help.
Emile Maras
Phys.Org News Partner Mathematics news on Phys.org
'Moral victories' might spare you from losing again
Fair cake cutting gets its own algorithm
Effort to model Facebook yields key to famous math problem (and a prize)
Shyan
#2
Dec12-13, 06:37 AM
Shyan's Avatar
P: 771
For the first atom,there is M choices...for the second,again M choices...for the third,again M choices...and so on!
So there is always M possible choices and all that we should do is to multiply the number of choices for each of the atoms which becomes [itex] M^n [/itex]. But because the atoms are identical,we should decrease this amount by dividing it by [itex] n! [/itex].
EmileMaras
#3
Dec12-13, 08:32 AM
P: 2
I guess that it is not the correct answer. Maybe I did not state my problem properly, so I will just give an exemple.
Let's say I have n=3 atoms and M=3 object. An object can contain at max nmax=2 atoms. Then the possible combinations are 111, 012, 021, 102, 120, 201, 210 (where xyz gives the number of atom in each object) which corresponds to 7 combinations.
Shyan
#4
Dec12-13, 08:46 AM
Shyan's Avatar
P: 771
Quote Quote by EmileMaras View Post
Yeah,my answer is wrong.It even gives a non-integral value!
Anyway,Check here!
Register to reply
Related Discussions
Combinations with Irregular Repetition Set Theory, Logic, Probability, Statistics 3
Calculating number of possible combinations with limited repitition Set Theory, Logic, Probability, Statistics 16
Combinations with limited repitition General Math 10
Does Ohm's Law still apply when the total number of Amps is limited? General Physics 2
Combinations with repetition (an intuitive way to it?) Set Theory, Logic, Probability, Statistics 2
