Register to reply
Summing divergences and the real projective line
by japplepie
Tags: divergences, line, projective, real, summing
Share this thread:
japplepie
#1
Dec13-13, 01:18 AM
P: 38
The real projective line states that there is not difference between positive and negative infinity (maybe except the path needed to be taken to "reach" either one of them) and they are actually connected.
There are a lot of ways to get a definite sum from a divergent series; one of which is the algebraic way (my personal favorite).
note:j(x)=x^0+x^1+x^2+x^3+...
Using the algebraic method I could derive the sum of j(2) as shown below:
j(2)=1+2+4+8+16+...
j(2)=1+2j(2)
j(2)= -1= 1+2+4+8+16+...
Does this mean that j(2) diverges so much that it went pass infinity from the positive side and landed on a definite negative point?
If the statement above is true, then the idea of < and > falls apart.
Example:j(2)+j(1/2)-1=0 ( the extra -1 here is to account for the (1/2)^0 )
A sum of all positive numbers that equals 0.
A notion of < and > that would work in this scenario is by measuring how far it "moved" in the RPL.
j(2)+j(1/2)-1 "moved" and circled back to 0, but 0 never "moved".
j(4)=1+4+16+64+256+...
j(2)=1+2+4+8+16+32+64+128+256...=(1+2)+(4+8)+(16+32)+(64+128)+...
j(2)=3+12+48+192+...=3(1+4+16+64+...)
j(2)=3j(4)
S2:={1,2,4,8,16,32,64,128,...}
S4:={1,4,16,64,256,...}
S2\S4={2,8,32,128,...} which is S4 multiplied by 2 element-wise
S2-S4=2(S4) (treat it like a sum)
S2=3(S4)
Does this also mean that in j(x), the smaller x (x>=1), the bigger* it is.
Bigger* meaning it "moved" more.
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Office_Shredder
#2
Dec13-13, 09:31 AM
Emeritus
Sci Advisor
PF Gold
P: 4,500
We actually had a similar thread here already not too long ago
http://www.physicsforums.com/showthread.php?t=727863
Basically the moral of the story is that you shouldn't take the results of manipulating divergent series too seriously.
gopher_p
#3
Dec13-13, 10:31 AM
P: 477
Quote Quote by japplepie View Post
The real projective line is the one point compactification of the real line. It is a topological space, not a sentient being with the ability to communicate. It does not state anything.
In this space, there is no "positive" infinity or "negative" infinity. There are not two points to differentiate. There is one new point. Saying that this point is different from itself in some way is ridiculous.
j(2)=1+2+4+8+16+...
j(2)=1+2j(2)
This method assumes a lot of things about infinite sums; namely that this one in particular is a number and that all of the algebraic properties of finite addition and multiplication can be extended to infinite addition, whatever the hell that is. Since you haven't stipulated what infinite addition is nor why we should accept the aforementioned assumptions, there is no way to tell what your result "means".
Why? There are two very obvious linear orderings of the real projective line which extend the usual ordering on the reals.
Maybe you mean that this new ordering doesn't "play with" addition on the real projective line the same way the old ordering did on the real line. But regardless of where you put ∞ in this ordering, under the usual assignment of a+∞=∞ the theorems involving order and addition are still true.
So this is really about how your infinite addition interacts with the ordering. Again, until you tell us what infinite addition is, we can't confirm any observation regarding how the order is broken.
j(2)=3j(4)
S2=3(S4)
japplepie
#4
Dec13-13, 08:59 PM
P: 38
Quote Quote by gopher_p View Post
It means that the idea behind it states ...
And yes infinite operations are still very shady.
Register to reply
Related Discussions
1^∞, 0^0 and others on the real projective line General Math 34
Convexity in the real projective plane? Differential Geometry 2
Real projective plane Differential Geometry 2
The Real Line Introductory Physics Homework 4
Real line is used to mean real axis General Physics 3
