Complex IR absorption surface
by oneill38
Tags: absorption, complex, surface
oneill38
oneill38 is offline
#1
Dec13-13, 07:45 AM
P: 1
Hi everyone,
I have a problem a bit tricky to solve which deals with Infrared absorbers.
In my setup experiment, some IR radiations are emitted, let's say black body radiations at 300K, so IR wavelengths centered on 10,6Ám.
I want to absorb them (entirely) by a surface (at about 77K) made of several layers to prevent my system from any heating. Consequently, I also want to prevent from IR reflection on this surface.
Maybe some of you can help me to "build" this surface.
For the moment, I have been thinking about a surface made of : (from outer to inner layer)
- layer 1 : Diamond (Good IR transmission 70% (10Ám), quite low reflection 15%). It has to be diamond, it cannot be changed.
- layer 2 : Silicon or Zinc Selenide (To absorb/reflect emission from absorber (layer3))
- layer 3 : Fused Silica (To absorb the main IR radiations : Huge absorption band and IR range between 5 to 80Ám). However some annoying things are the 2 peaks of reflection at 9 and 21Ám ...
Layers has to be thick as possible...
If anyone of you have some ideas or advise regarding as materials (SiO, Black Silicon ...) I did not mention or did not think about, please tell me, I will be glad to know :)
Thanks in advance
Have a nice day.
Phys.Org News Partner Physics news on Phys.org
Researchers develop scalable methods for manufacturing metamaterials
Researchers find tin selenide shows promise for efficiently converting waste heat into electrical energy
After 13 years, progress in pitch-drop experiment (w/ video)
Register to reply
Related Discussions
Finding Surface for Complex ParametricPlot3D Calculus 1
Is there any parallel in Complex Analysis to a surface integral? Calculus 4
Complex dielectric constant implies absorption? Atomic, Solid State, Comp. Physics 10
Why is the mass absorption coefficient used rather than the linear absorption? Advanced Physics Homework 1
Advice on complex analysis, Riemann surface & complex mappings. Differential Geometry 3
