Register to reply
Secret folders
by mech-eng
Tags: folders, secret
Share this thread:
mech-eng
#1
Dec13-13, 10:54 AM
P: 151
there is a strange virus.It seems that it has a name of recycle.Problem is that when it enters our flash memory it changes all created folder with their shortcuts.ı can reach them by these shortcuts.
But when I deleted that shortcuts I cant reach folder normally from a windows 7 window.but they are really there.I can reach and monitor them by some programs such as winrar.I run winrar and using
up button I select the memory and enter into it by winrar.I can see all folder in winrar but not in the
operating system's window.what is the problem with folders.how can make them normal?
Phys.Org News Partner Science news on Phys.org
Suddenly, the sun is eerily quiet: Where did the sunspots go?
'Moral victories' might spare you from losing again
Mammoth and mastodon behavior was less roam, more stay at home
phinds
#2
Dec13-13, 11:13 AM
PF Gold
phinds's Avatar
P: 6,068
Quote Quote by mech-eng View Post
Just tell Windows Explorer to show hidden and system files
mech-eng
#3
Dec17-13, 07:10 AM
P: 151
Quote Quote by phinds View Post
how can I tell Windows explorer to show . I entered control panel and chose folder options and
then clicked on "show hidden files and folder" and then a dialog window called folder options opened.In the view button I chose "show hidden files,folders and drivers" and then clicked on "ok" button.but I see that nothing has changed.
Enigman
#4
Dec17-13, 07:17 AM
Best Humor
Enigman's Avatar
P: 555
Secret folders
Its probably the RECYCLER virus and most modern antivirus softwares can get rid of it for you.
mech-eng
#5
Dec17-13, 07:53 AM
P: 151
Quote Quote by Enigman View Post
yes I can get rid of it but the problem is I cant make folders visible again.
Borek
#6
Dec17-13, 08:30 AM
Admin
Borek's Avatar
P: 23,363
Control panel, Folder options, View, Show hidden files, directories and drives.
At leas under W7, I am translating from Polish, so exact names can be slightly different.
mech-eng
#7
Dec17-13, 08:44 AM
P: 151
Quote Quote by Borek View Post
I did like you said but nothing has change is it because of secret folders in a flash memory.
rcgldr
#8
Dec17-13, 09:46 AM
HW Helper
P: 7,030
Is it possible to copy the entire flash memory to a folder on a hard drive, then compare to verify everything was copied, then "unhide" all the folders that you don't want hidden, then "format" the flash memory, and then copy back to the flash memory?
mech-eng
#9
Dec17-13, 10:11 AM
P: 151
Quote Quote by rcgldr View Post
I tried what you said.I did as in the Picture I attached but nothing has change.They are still unvisible.there must be another tip.
Hepth
#10
Dec17-13, 10:35 AM
PF Gold
Hepth's Avatar
P: 466
There is more than show hidden files and folders, you must ALSO show system files, which is a little bit farther down in that thumbnail above, or rather uncheck the "hide system files" one.
Enigman
#11
Dec18-13, 05:04 AM
Best Humor
Enigman's Avatar
P: 555
Antivirus should have fixed that...but aside that a google search suggests this to show all hidden files in a directory:
1. Click on "Start" -->Run --> type cmd and click on OK.
2. Here I assume your External hard drive as G:
3. Enter this command.
4. attrib -r -a -s -h g:\*.*
(replace g with your drive letter)
mech-eng
#12
Dec18-13, 12:03 PM
P: 151
Quote Quote by Hepth View Post
Your method works very well. I unchecked "hide protected operating system files(recommended)" and it is ok. But there is not any box being "Show system files" for checking and I can see files but they are transparent. they are not still normal in spite of being visible. Is my O.S regards them as system files in spite of they are not?
xAxis
#13
Dec18-13, 09:12 PM
P: 208
It's OK. You're doing fine. Now just do what Enigman sad in post 11
adjacent
#14
Dec18-13, 11:49 PM
PF Gold
adjacent's Avatar
P: 1,456
1-Make a new folder(This should be normal)
2-Copy all the files/sub-folders present in the affected folder to new folder
3-Then delete the transparent/original folder.
Problem solved
This is what I did when "Chir.B.worm" virus got into my computer.
It makes all the folders into shortcuts just like how you said.
mech-eng
#15
Dec20-13, 10:37 AM
P: 151
when I try this command prompt says -r is not recognized as an internal or external command,operable program or batch file and can you share your Google criteria for that search.
AlephZero
#16
Dec20-13, 04:33 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,915
The command you type is attrib -r -a etc. The error message suggests you just typed -r -a etc.
Here's the documentation: http://www.microsoft.com/resources/d....mspx?mfr=true
HowlerMonkey
#17
Dec26-13, 06:33 PM
P: 276
Removing all the attributes on the entire hard drive *.* could cause issues with certain software packages that depend on something being read only attribute as well, it opens up any file to be modified.
Register to reply
Related Discussions
Forum Folders Forum Feedback & Announcements 12
Can ntfs folders be mounted under ntfs folders? Computing & Technology 2
Cant rename folders on desktop Computing & Technology 7
How many folders? Precalculus Mathematics Homework 1
Content.IE5 Folders Computing & Technology 3
