Peaks at reflectance spectrum
by hjelmgart
Tags: peaks, reflectance, spectrum
hjelmgart
hjelmgart is offline
#1
Dec13-13, 06:24 PM
P: 124
Hello,
I am currently analysing some relfectance data I obtained from measurements on several silicon samples. During the process I used the standard fresnel coefficients, and suddenly I began to wonder, what the peaks describe? The last graph at this link shows it for normal incident light, I think.
My typical approach is to relate peaks to the band gap, but then I remembered silicon has a band gap of 1,1 eV.
So what explains the peaks? I am still thinking, that it is related to the band gap. But the band gap isn't constant either? The 1,1 eV is just the lowest gap, right?
So do the peaks represent different band gaps with respect to the brillouin zone, or how is it?
Any suggestions or explanations appreciated! Or possibly a source, that explains it, as I so far had no luck at finding such.
Phys.Org News Partner Physics news on Phys.org
Researchers find tin selenide shows promise for efficiently converting waste heat into electrical energy
After 13 years, progress in pitch-drop experiment (w/ video)
Global scientific team 'visualizes' a new crystallization process (w/ video)
Claude Bile
Claude Bile is offline
#2
Dec31-13, 09:31 AM
Sci Advisor
P: 1,465
One reflectivity peak is due to a peak in the real refractive index, the other is due to a peak in the imaginary refractive index: and that the formula for calculating reflectivity applies for real- and complex-valued refractive indices.
Note too, that the real and imaginary refractive index components are linked via the Kramers-Kronig relations.
Claude.
Register to reply
Related Discussions
Identification of radiation source from gamma spectrum peaks. High Energy, Nuclear, Particle Physics 2
Assigning peaks in a Raman spectrum/ group theory Biology, Chemistry & Other Homework 0
How many peaks will there be in an NMR spectrum for Malic Acid? Biology, Chemistry & Other Homework 2
How many peaks in NMR spectrum of Malic Acid, without D2O? Biology, Chemistry & Other Homework 0
Algorithms for spectrum peaks? Programming & Computer Science 0
