What is specific intensity anyway?
The discussion centers on the concept of specific intensity, defined as the measure of radiation emitted, transmitted, or received in a specific direction, typically quantified in watts per square meter per steradian (W/m²/sr). The specific intensity of solar radiation at the solar surface directed towards Earth varies based on wavelength and distance, while the intensity at Earth's surface is further influenced by atmospheric absorption and scattering. To calculate specific intensity values, one must apply relevant equations, including the Stefan-Boltzmann law for blackbody radiation.
  • Understanding of radiative transfer principles
  • Familiarity with the Stefan-Boltzmann law
  • Knowledge of electromagnetic radiation spectrum
  • Basic concepts of atmospheric science
  • Research the Stefan-Boltzmann law and its applications in radiative transfer
  • Explore the electromagnetic spectrum and its impact on specific intensity
  • Study the effects of atmospheric absorption and scattering on solar radiation
  • Learn about measuring specific intensity in various contexts
Physicists, atmospheric scientists, and anyone involved in the study of radiative transfer and solar radiation analysis will benefit from this discussion.
OETN
Hi all,
I need a hand regarding this problem, just can't seem to find the start point. (It's a two parter):
What is the specific intensity of the radiation at the solar surface in the direction of Earth
What is the specific intensity of solar radiation at the surface of the Earth.
As you can see, isn't really specific on values so it would seem you have to quote any used values. Would be great if anyone could help.
ON
e possible explanation of specific intensity is that it is a measure of the amount of radiation (such as light or heat) that is emitted, transmitted, or received in a specific direction. It is a physical quantity that is used in the study of radiative transfer, which is the process of energy transfer through electromagnetic radiation. Specific intensity is typically measured in units of watts per square meter per steradian (W/m2/sr).
To answer the first part of your question, the specific intensity of radiation at the solar surface in the direction of Earth would depend on the wavelength or frequency of the radiation being emitted. The sun emits radiation across a wide range of wavelengths, from infrared to ultraviolet. The specific intensity would also depend on the distance between the sun and Earth, as the intensity of radiation decreases with distance.
For the second part of your question, the specific intensity of solar radiation at the surface of the Earth would again depend on the wavelength and distance. However, it would also be affected by factors such as the Earth's atmosphere, which can absorb and scatter some of the incoming radiation. This is why the specific intensity of solar radiation at Earth's surface is lower than at the solar surface.
To find specific intensity values for these scenarios, you would need to use equations that take into account the relevant variables, such as the Stefan-Boltzmann law for blackbody radiation. It is important to note that specific intensity can vary greatly depending on the specific conditions and context in which it is being measured. I hope this helps clarify the concept of specific intensity for you.
  • · Replies 16 ·
