| Thread Closed |
Super Free Will: Metaprogramming and Quantum Indeterminism |
Share Thread |
| Apr27-05, 12:44 AM | #18 |
Super Free Will: Metaprogramming and Quantum IndeterminismFree will is more than just being able to foresee the consequences of one's actions. In addition one must be able to choose from alternatives, and one must act such that one's choice appears rational and yet not consistently predictable. Some might also argue that an agent must have a consciousness in order to have free will - I am not so sure about this (though one would need to be conscious in order to know that one has free will ).QM I have already commented on - there is nothing in QM or anywhere else which says the world is necessarily indeterministic. I'm not sure what your expression "seems the consequence argument non free will'st use is kinda shot." means - can you re-phrase that please? MF
| Apr27-05, 01:18 AM | #19 |
MF
| Apr27-05, 09:20 AM | #20 |
Its off thread, so i'll be brief (at least for me)
I agree with Artermis (post 17)- it does not make much diff if brain function is by chemistry or electrical, but the influx of Na+ ions into the axion that is a progressive wave traveling away (usually) from the cell body is best view as a discharge of the 70mv negative "resting potential" of the axion interior that the "Na pump" must restore before the next action potential discharge can occur (the "refractory period"). This part of brain activity is best considered "electrical" and is well modeled by electrical concepts, such as capacitors, voltages, currents, etc. (E.g. the reason that mylinated nerves have different conduction speeds and the reason that large vs small cross section axions have different effects upon conduction speed all fall out correctly from these electrical models.) Once these "electrical impulses" arrive at the "pre-synaptic" junction, the chemical view is much more appropriate. E.g. GABA (a universal inhibitory neurotransmitter) release into the "synaptic gap" is only possible if the pre-synaptic GABA molecules are there. Once the neurotransmitters are in the gap, then Brownian motion physics is the preferred (at least by me) model. I'll stop here as now it really gets complex and this is off thread "correction" to prior posts. |
| Apr27-05, 11:40 AM | #21 |
| Apr27-05, 12:43 PM | #22 |
Be this as it may, I think both the math and physical chaotic systems do in fact have epistemic limits. In the math form of chaos, it is that most (if not all - I don't know if some very clever mathematician has built one on only the integers etc.) will involve irrational numbers and these are always only expressible as approximations. I.e. there is an epistemic limit to our knowledge of their value, but it can be as accurate as you are willing to pay for. (I recently read that some Japanese supercomputer had PI's value out to some very large number of places but the value of PI is still epistemicly unknowable.) As for the chaotic physical systems, it is obvious that no measurement of the initial condition is perfect so where the system will be after a long period of deterministic movement is basically anywhere on the conserved quanties surface - ie the ergotic theorem - provided there are no "regions excluded" for reasons that are not clear, at least to me, but are some sort of physical constraints. |
| Apr27-05, 01:53 PM | #23 |
Please define what you mean by "determinate". If you mean "epistemically determinable" then I agree chaos theory says that chaotic systems are epistemically indeterminable. If you mean "ontically deterministic" then I think you will find that an ontically deterministic system continues to be ontically deterministic even if it is chaotic. MF
| Apr27-05, 02:12 PM | #24 |
| Apr27-05, 03:50 PM | #25 |
Thus, it seems that by “determinate” you did indeed mean “deterministic” when you said “It just says that the behavior of the system is determinate, whereas the behavior of its lower-level constituent parts is not.”, in which case I disagree with this statement. If the behaviour of a chaotic system is deterministic, then there is NO reason (from chaos theory) to suspect that the behaviour of its “lower parts” is not also deterministic. MF
| Apr27-05, 06:52 PM | #26 |
The behavior of the system can be determined, whereas the behavior of its lower-level constituent parts cannot be determined, whether or not they are deterministic. What do you know? I just looked it up, and I am right to say that my definition conforms exactly to the definition given in the dictionary based on the way this word is commonly used. I will promise you this, MF: If I should use terms that I made up or that have ambiguous or unclear definitions, then I will do my best to define them in the post. Doing so really wasn't necessary here and has only detracted from what was actually being discussed. By the way, I did say I was pretty certain that the defenders of this line of reasoning are defending libertarian free will, which you seem to understand pretty well as you formed a cogent response to it at the bottom of your post. |
| Apr27-05, 11:19 PM | #27 |
Just so I don't have to be so patronizing with you folks (I know I can be and I'm sorry), I found a list of common terms here. If I use any of these, the given definitions are what I intend. I actually hadn't heard of some of these before.
| Apr28-05, 12:54 AM | #28 |
Sorry to repeat myself, but in absence of a clear definition of a concept like determinism, it is meaningless to discuss determinism. Simply saying that "determinism is variously used" does not lay sufficient groundwork for making any progress, all it does is make further discussion of the term meaningless. Thanks MF |
| Apr28-05, 01:37 AM | #29 |
The phrase “can be determined”, by virtue of the qualifying “can be”, implies an epistemic property of the world – ie that “an observer can determine”. It is possible for a world to be “determined” (an ontic property) without at the same time it being possible for “an observer to determine it” (an epistemic property). The phrase “can be determined” is thus another way of saying “epistemically determinable” (and “cannot be determined” is another way of saying “epistemically indeterminable”). One of the defining properties of chaotic systems (the reason they are called chaotic) is that they are indeed epistemically indeterminable. Determinate in my dictionary is defined as follows : “Precisely determined or limited or defined; especially fixed by rule or by a specific and constant cause.” Determinate is thus an ontic property, it says something about “how the world is”, and not “what we can know about the world”, it says nothing about epistemology. By this definition, a chaotic system could be “determinate”, but it could still be impossible for an “observer to determine” that system. It is only by clearing this up that we have identified your mistake and finally arrived at what you intended to say. With respect, this is exactly the kind of confusion and ambiguity in the use of words and phrases that I have been trying to point out. Unless one uses terms very carefully, and very clearly defined, one will end up making (at best) meaningless statements or (at worst) incorrect statements. With respect, your confusion between the phrase “can be determined” and the word “determinate” are IMHO examples of the kind of ambiguity that libertarians also need to resort to to defend their concepts. MF
| Apr28-05, 02:02 AM | #30 |
| Apr28-05, 02:26 AM | #31 |
| Apr28-05, 04:50 AM | #32 |
Determinate in my (Websters) dictionary is defined as follows : “Precisely determined or limited or defined; especially fixed by rule or by a specific and constant cause.” You seem to use “indeterminate” as meaning “not epistemically determinable”, whereas I would not equate these two terms (I equate “indeterminate” with “not ontically deterministic”), given the above definition of determinate. Again, I am curious to know eaxctly how your dictionary defines “determinate”? IMHO this is why we need to be very clear and precise in our definitions, and not simply assume that everyone uses the same (textbook) definition of these terms. I agree with this as a description of some of the properties of free will. The description is also completely consistent with determinism. “I can find nobody who can define, unambiguously and rationally, exactly what it is and then defend that definition in any way that makes rational sense.” “I can find nobody who can define, unambiguously and rationally, exactly what it is and then defend that definition in any way that makes rational sense.” What is unclear here? MF
| Apr28-05, 05:16 AM | #33 |
Just for clarity : The whole reason we got into this “show me your definition” wrangle was because you used the word “determinate” in post #21 of this thread, in a sentence which (given my Webster’s definition of “determinate”) I could not make sense of. I therefore asked you to define what you mean by determinate (post #23), but you declined to give a definition (post #24) saying instead “I mean exactly what you mean when you defined it earlier”, when in fact I had not (prior to your first use of the word) used the word “determinate”, let alone defined the word, in this thread. Finally in post #26, still not having defined what you meant, you removed the phrase “is determinate” and replaced it with “can be determined”, thereby changing the meaning of your sentence. As I have said all along, “is determinate” is ontic, “can be determined” is epistemic. Determinism as defined by you above is also ontic. I see no incompatibility at all between your definition of determinism and mine, which is : Definition of Determinism : The doctrine that the universe, or any self-contained part thereof, has only one possible state at time t1 which is consistent with its state at some previous time t0 and with all the laws of nature. MF
| May1-05, 01:02 PM | #34 |
i'm pretty sure we hold the same view on this topic, so it's just a matter of semantics. |
| Thread Closed |
Similar discussions for: Super Free Will: Metaprogramming and Quantum Indeterminism
| Super Numbers and Super calculus | General Math | 12 | ||
| Super learning and super brain | Social Sciences | 18 | ||
| Electron indeterminism Problem | Quantum Physics | 42 | ||
| Indeterminism... | General Math | 18 | ||
| Super to Subcritical, and Super to Subsonic Flow | Mechanical Engineering | 2 | ||
