Why does each element only react with certain elements?
In summary, the specificity of reactions between elements is determined by their electron configurations and the stability of resulting compounds. While every element has the potential to bond with any other, many compounds formed would be unstable and quickly dissociate, leading to the belief that certain elements do not react with each other. Factors such as electronegativity and the possibility of forming more stable compounds also play a role in determining which elements will react with each other.
herozs
I want to know what causes this specificity of reactions in between elements. Why does carbon only react with X elements? What are the factors that come into play to cause this specificity?
From what I understand every element has the potential to bond with every other element but a lot of them would form unstable compounds and would dissociate quickly and so we say x element doesn't react with x element. For example could Na form a covalent bond with Ca but since they would form an unstable compound it quickly dissociates, so we say Na doesn't react with Ca?
So, does each element have the potential to bond with any other? and because many would form unstable compounds we say they don't react? If not, again what is it that causes the specificity?
PS- small question here that I don't think it deserves a thread.
When a polar bond dissociates does the more electronegative element always keeps the electron of the less electronegative element
(R-OH --> R-O: ( O with extra electron) H+)?
Also with non-polar bonds does the opposite happen when it dissociates (C-H -> C + H)?
Where both elements stay neutral?
Thank you very much.
Chemistry news on Phys.org
whether a covalent bond is formed depends on how many electrons are in the outermost shell (how full it is for eg) and what other possibilities there are that may be more likely. Eg. An atom could just strip the electrons from another one.
not always but generally.
The element is more electronegative because the electron is more likely to be found close to it.
no.
The dissociation of molecules can be quite complicated.
Some end configurations are more likely than others... But look at the stability of the possible ions in your example.
Okay thanks man, but for what reasons do we say X element will only react with X elements?
Or is it that all the elements have the potential to form bonds with every other element but a lot of the compounds that would form would be very unstable and just dissociate?
We "say" that stuff because that is true.
A noble gas, for instance, does not react with anything.
Platinum is an example of something that reacts so well with everything that it can tear other molecules apart in the process - but the bonds are so unstable that they break apart almost right away.
The comparison should help you with your question.
How stable the bonds are and what atoms will react with which depends on the electron configuration and what else they could do.
I can explain the specificity of reactions between elements through the concept of chemical bonding. Each element has a unique atomic structure, with a specific number of protons, neutrons, and electrons. These electrons are arranged in different energy levels or orbitals around the nucleus.
In order to attain a stable electronic configuration, elements will either gain, lose, or share electrons with other elements. This process is known as chemical bonding. However, not all elements have the same tendency to gain, lose, or share electrons. This is due to factors such as the number of valence electrons, electronegativity, and atomic size.
For example, carbon has four valence electrons and a moderate electronegativity, making it capable of forming covalent bonds with a variety of elements. On the other hand, elements like sodium and calcium have low electronegativities and a tendency to lose electrons, making them more likely to form ionic bonds with elements that have a higher electronegativity.
Additionally, the size of an atom also plays a role in the specificity of reactions. Smaller atoms have a stronger attraction for electrons, making them more likely to form covalent bonds, while larger atoms tend to form ionic bonds.
Furthermore, the stability of the resulting compound also plays a role in the specificity of reactions. As you mentioned, some combinations of elements may form unstable compounds that quickly dissociate, making the reaction less likely to occur.
In regards to your question about polar and non-polar bonds, the behavior of the elements during dissociation depends on the type of bond. In a polar bond, the more electronegative element will typically keep the shared electrons, while in a non-polar bond, both elements will keep their own electrons.
In conclusion, the specificity of reactions between elements is determined by several factors such as valence electrons, electronegativity, atomic size, and stability of resulting compounds. These factors work together to determine the types of bonds that can form between different elements.
1. Why do elements only react with certain elements?
Elements only react with certain elements because of their unique atomic structure. Each element has a specific number of protons, neutrons, and electrons in its atoms, which determine its chemical properties. When elements react, they are trying to achieve a stable electron configuration, and certain elements are only able to form bonds with specific elements that can help them achieve this stability.
2. How do elements determine which elements to react with?
The number of valence electrons in an element's outermost energy level is the main factor in determining which elements it can react with. Elements with the same number of valence electrons tend to have similar chemical properties and are more likely to react with each other. Additionally, elements with incomplete outer energy levels are more reactive and will often react with other elements to form compounds.
3. Are there any exceptions to elements only reacting with certain elements?
Yes, there are some exceptions to this rule. Some elements, such as carbon, can form bonds with a wide range of other elements. This is because they have a unique ability to form multiple bonds and can share electrons with many different elements. Additionally, some elements can form bonds with elements that have a different number of valence electrons, but this is less common and often results in less stable compounds.
4. Can elements react with any element under certain conditions?
In certain extreme conditions, elements may be able to react with elements that they would not usually react with. For example, under very high pressure and temperature, elements may undergo nuclear reactions and form compounds with elements that they would not normally react with. However, these conditions are not common on Earth and are not considered typical chemical reactions.
5. Why do some elements not react with any other elements?
Some elements, such as the noble gases, do not react with any other elements because they have a full outer energy level and are already stable. These elements do not need to form bonds with other elements to achieve stability, so they do not react with them. Additionally, some elements may not react with other elements due to their electronegativity or other chemical properties that make it difficult for them to form bonds.
  • Chemistry
