Register to reply
Where does it come from?
by Kruger
Tags: None
Share this thread:
Kruger
#1
Apr25-05, 11:21 AM
P: 219
Where does a photon in vacuum come from if it creates a pair? In QFT there shoudn't be a photon available in vacuum because the number operator is zero.
Phys.Org News Partner Physics news on Phys.org
Physicists unlock nature of high-temperature superconductivity
Serial time-encoded amplified microscopy for ultrafast imaging based on multi-wavelength laser
Measuring the smallest magnets: Physicists measured magnetic interactions between single electrons
dextercioby
#2
Apr25-05, 11:44 AM
Sci Advisor
HW Helper
P: 11,895
For the quantum theory of the em field,the vacuum state has 0 particles...
But QED means INTERACTING quantum fields:Dirac & Maxwell.
Daniel.
Kruger
#3
Apr25-05, 01:05 PM
P: 219
Which Dirac theory? I know the Hole theory. But this theory does only describe the positron and electron, not the virtual photon. Can you tell me?
thanks dextercioby
dextercioby
#4
Apr25-05, 01:27 PM
Sci Advisor
HW Helper
P: 11,895
Dirac field.The vacuum for a free field has 0 energy,0 momentum,0 electric charge & 0 particles (remember the necessity of defining the normal product of creation & annihilation operators).But the vacuum for an interacting field theory is different.Remember that the quantum corrections to the Green functions are nonzero.
Daniel.
Kruger
#5
Apr26-05, 03:31 PM
P: 219
Can you please explain me, why the quantum corrections for this aren't as normal. Normal we have E=hw/4pi.
dextercioby
#6
Apr26-05, 03:59 PM
Sci Advisor
HW Helper
P: 11,895
Nope.The normal product deals with "residual" energy.The vacuum of a free theory has 0 energy.
Daniel.
marlon
#7
Apr26-05, 05:59 PM
marlon's Avatar
P: 4,006
Quote Quote by Kruger
Here we go again. I urge you to read the 'on virtual particles' entry of my journal. Vaccuum fluctuations only arise in NON-free field theories. In these theories the number operator is NOT conserved because it does not commute with the Hamiltonian. The actual fluctuations arise because of the HUP and this non-conservation of the number operator. Energy can become uncertain for a very short time. During this time, energy conservation is violated and the number operator will change...
marlon
http://www.physicsforums.com/journal...page=10&page=2
you will need to scroll a bit
Kruger
#8
Apr27-05, 05:16 AM
P: 219
But if I derive the ground state of the electromagnetic field I would get the zero point energy of this quantum field. And there aren't photons in there. And that's why I think there aren't photons in the vacuum (not real photons and not virtual photons <--- in an empty space where only ground state oscillations can exist). If we put in a strong electric field Dirac's hole theory predicts virtual pair creation. But for this it is a virtual photon needed with many energy and ground state oscillation hasn't this energy.
I know that Heisenberg's uncertainty principle play a role in this but we used it in deriving the ground state of the em field. And that's actionally the point where I get problem.
OR DO WE CALL THIS GROUND STATE OSCILLATION "VIRTUAL PHOTONS"???
marlon
#9
Apr27-05, 09:16 AM
marlon's Avatar
P: 4,006
You need to distinguish between two things here. Virtual particles either arise because of vaccuum fluctuations, but they also originate as the force mediating particles between matter particles. In your example, the energy for the virtual particles does NOT come from the vaccuum but comes from the actual interaction between two matter particles. If you have two electrons that interact via the exchange of a virtual photons, then this photon arises as the fluctuation of a spin 1 field (this is a tricky issue however because of the zero photon mass). These fluctuations are caused by the two electrons. Think of the two electrons as if they were sitting on a mattress that will start to vibrate. These vibrations correspond to the virtual particle that goes from one electron to another. Both repulsive and attractive forces are treated this way in QFT. A force is represented by the exchange of this virtual particle that transports a definite momentum and therefore (because of HUP) the field corresponding to this virtual particle is everywhere in space...This really needs to be the case because when working with Feynmann diagrams and when calculating the photon propagator, we integrate over all spatial coordinates.
Now, the vaccuum can have an influence on this. If the vaccuum is filled with virtual particle anti-particle pairs, each with opposite charge, these pairs will act as good old dipoles and they will try to align with the electric field of the two electrons. Basically what happens is that the vaccuum plays the role of a dielectric that screens (ie : make more interactions more difficult) the electron's charges. That is why we have the concept of bare and dressed charge in field theory. This vaccuum-influence is expressed by the polarization insertion in QFT and this is nothing else then the self energy of the photon propagator
marlon
Kruger
#10
Apr27-05, 10:04 AM
P: 219
thanks dextercioby and marlon
In all books I read about the vacuum there is written something like this:
///In vacuum there are all electrons on their lowest state. There are also negative energy states which are occupied. If a virtual photon collide with such a negative energy particle then this negative particle gets positive energy and it leaves a hole back (negativ states) that behaves like a positron. After time d(t) (Uncertainty) the electron will go back in the negativ energy state.
How do they interact or better which particle interacts with whicht? I mean in Dirac's theory there isn't an electron that interacts. The negativ energy particle just raise into a positive energy state.
Kruger
#11
Apr27-05, 10:18 AM
P: 219
All the oscillators in the mattress are in their SAME lowest energy-state but each oscillator has virtual vibrations. So you have one particle with energy given by hbar*omega/2 but surrounded with many other virtual particles.
And another question about what you have written (journal).
If I look on quantum field theory then this mattresses don't contain particles. ???
marlon
#12
Apr27-05, 10:49 AM
marlon's Avatar
P: 4,006
No, they do not.
It's the vibrations that correspond to what we call particles
regards
marlon
Kruger
#13
Apr27-05, 10:54 AM
P: 219
But you wrote ""So you have one particle with energy given by ...""
marlon
#14
Apr27-05, 10:55 AM
marlon's Avatar
P: 4,006
I don't know what you are talking about. Please be more specific so that i can understand
regards
marlon
Kruger
#15
Apr27-05, 01:57 PM
P: 219
Sorry marlon.
I mean the last sentence you wrote. And I think that there aren't particles in the vacuum with this energy. (you wrote this in you journal (virtual particles)).
If we work with Diracs hole theory how can this be understood with your explanation? There aren't really two particles (only one) and that's the "electron" in the negative energy state that raise on a positive state (for short time d(t)) if a virtual photon interacts with it. But from where exactly does the virtual photon come from? <--- Please, can you explain me that in easy language (I only startet with QM and QFT, I'm not an expert like you, marlon and dexter)
Thanks
marlon
#16
Apr27-05, 03:20 PM
marlon's Avatar
P: 4,006
Sorry marlon.
OK i get your point. Well, if the mattress vibrates, there are several energies possible. One energy will be 'on mass shell' meaning it respects the Einstein energy relation. But apart from this energy, there are many other energies that do not respect the Einstein energy relation. These corrspond to the virtual particles. So indeed, there are no virtual particles that have the groundstate energy of the EM-field because it respects the Einstein energy relation. However, other energies are possible during a time delta t...Those are the virtual particles that arise and vanish shortly after.
regards
marlon
Kruger
#17
Apr27-05, 03:26 PM
P: 219
Ok, I think I got the case of my problem now. Thanks marlon you're very helpful.
Kruger
#18
Apr27-05, 03:37 PM
P: 219
So If there is created a virtual particle then the state of the mattress will raise. And after its annihilation the state will lower and go back to ground state.
These virtual particles (photons) are they a "product (intermediate state)" of an interaction or can they arise from vacuum (in case of virtual pair creation)? In the case of pair creation the e+e- pair isn't there at the beginning and the virtual photon must be an off mass shell interacting particle, so fom where does this photon come from (which particle send it)?
Register to reply
