Introduction of Oxygen and Hydrogen
by John1397
Tags: hydrogen, introduction, oxygen
John1397
John1397 is offline
#1
Dec27-13, 11:09 AM
P: 65
Does introducing small amount of hydrogen and oxygen with gasoline into an internal combustion engine make the sensor read lean and and just enter more gasoline?
John
Phys.Org News Partner Engineering news on Phys.org
New ultrasound device may add in detecting risk for heart attack, stroke
Enhanced ground control system and software for small unmanned aircraft
SensaBubble: It's a bubble, but not as we know it (w/ video)
bigfooted
bigfooted is offline
#2
Dec29-13, 03:41 PM
P: 265
what kind of sensor is it? CO2? or O2? Do you measure the combustion products only? Adding hydrogen will will consume O2, but not change CO2 in the products,so an O2 sensor will detect that you are burning richer and a CO2 sensor will not. Adding oxygen will of course make it lean and CO2 and O2 sensors will both pick this up.
copracr
copracr is offline
#3
Jan5-14, 12:34 PM
P: 2
I'm not a chemist but I am an auto tech. My assumption would be that it would depend on the ratio you added those elements. If they were added in a stoichometric ratio then the PCM would make no further changes due to complete combustion (you would get more work out of the engine though). If you added a lean hydrogen/oxygen mixture then the PCM would try and enrichen with gasoline until stoich is achieved and just the opposite would happen if you added a rich ratio.
BTW, auto engines use an O2 sensor. Most PCM's (that's the engine computer) use the O2 sensor to fine tune the air-fuel ratio once the engine is warmed up and running in closed loop mode.
John1397
John1397 is offline
#4
Jan5-14, 04:22 PM
P: 65
Sounds like if you put hydrogen or gasoline into a motor the o2 sensor will send back a signal depending if you add to much fuel or to little it would send back a to rich or to lean signal regardless of kind of fuel is added. If you run a motor on 14:1 ratio of either hydrogen, gasoline, or even propane the o2 sensor will send back the same reading if I understand correctly?
copracr
copracr is offline
#5
Jan5-14, 04:47 PM
P: 2
Quote Quote by John1397 View Post
Exactly. Fuel is fuel. It's the incomplete combustion that is indirectly measured by the presence of free O2 in the exhaust that makes the engine computer make adjustments.
Also, bear in mind the engine PCM doesn't always desire 14:1. If you're working on a project, bear in mind that leaner mixtures are sometimes commanded by the PCM. Ratio's upwards of 55:1 during coasting can be called for (and some turn off the fuel completely for coasting conditions)
Register to reply
Related Discussions
How to Generate Hydrogen and Oxygen General Engineering 5
Inhaling Hydrogen+Oxygen General Physics 5
Mixture of hydrogen and oxygen Chemistry 7
creating oxygen(co2) out Of hydrogen Astrophysics 5
Speed of Hydrogen / oxygen Introductory Physics Homework 6
