Register to reply
Looking to sniff out smart meter RF
Share this thread:
MissyDissy
#1
Dec29-13, 07:43 PM
P: 1
Hey everyone
I hope I am posting this in the right place.. After all this is my first post here.
I am looking to track down what RF (radio frequency) my local smart meters are broadcasting in. I have been doing some research but would like to know if anyone has any experience with this. My end result would be to try and decode the information being broadcasted out. I'm not sure what frequency range to sniff around but I know other districts run around the 902 MHz - 928 MHz range. Would I need a real expensive spectrum analyzer? Turning my computer into a RF scanner would be the ideal if there is hardware for that.
Missy
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
dlgoff
#2
Dec29-13, 09:45 PM
Sci Advisor
PF Gold
dlgoff's Avatar
P: 2,726
Welcome to Physics Forums.
It shouldn't be a problem "hearing"/coupling to a Power Line Carrier. Heck, after my power utility queries my smart meter, I can audibly hear the data pulse stream in my fluorescent light ballast.
Typically home-control power-line communication devices operate by modulating in a carrier wave of between 20 and 200 kHz into the household wiring at the transmitter.
Baluncore
#3
Dec30-13, 05:13 AM
Sci Advisor
Thanks
P: 1,921
Power line carriers are one technology but RF interfaced meters are another.
Your meter will probably not broadcast data on RF without first being interrogated by a controller. You will not benefit from a spectrum analyser while identifying those details. Indeed it may not work at all since the SA cannot trigger a transmission from the meter.
I have always found it easiest to identify the exact model of the meter and then get the manufacturers data sheet from the web. That will usually give sufficient information to identify the system employed in your region. Either the band, mode and carrier frequency will be specified in the data sheet, or a channel will be licensed by the frequency allocation authority to the power company. That allocation is usually publicly available.
berkeman
#4
Dec30-13, 11:34 AM
Mentor
berkeman's Avatar
P: 41,098
Quote Quote by MissyDissy View Post
Hey everyone
Missy
The meter reading data are encrypted for a reason. Do not try to hack into private information that can be used for illegal purposes. Thread is closed.
Register to reply
Related Discussions
Smart Meter radiation concerns General Discussion 9
Purdue students sniff manure for science General Discussion 5
Smart Tweezers R-L-C Meter Electrical Engineering 2
HELP ON A WORK PROBLEM.. CAN'T DO IT BY MYSELF.. SNIFF SNIFF.:cry: Introductory Physics Homework 3
*sniff* Thanks Introductory Physics Homework 4
