Register to reply
Question about temperature and Specific Weight
by petersun825
Tags: specific, specific weight, temperature, weight
Share this thread:
petersun825
#1
Dec30-13, 12:20 AM
P: 5
Hello,
I know there are many different representations of temperature, there's 4, 1) Fahrenheit 2) Kelvin 3) Celsius then there's 4) T = 460 + F
In my fluid dynamics review book To calculate specific weight γ= P(pressure) / (R * T) = lb/ft^3, it explained that T should be absolute temp so I used 2) kelvin, but the book used 4) T = 460+F
Can somebody explain what 460 + F stands for??
Thanks,
Peter
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
Borek
#2
Dec30-13, 03:24 AM
Admin
Borek's Avatar
P: 23,533
Absolute in this context means any scale for which zero is at absolute zero. 460+F is also known as a Rankine scale.
petersun825
#3
Dec30-13, 01:24 PM
P: 5
So Rankine scale goes with british units lb/ft^3 and kelvin scale goes with international units like kg/m^3?
Borek
#4
Dec30-13, 02:05 PM
Admin
Borek's Avatar
P: 23,533
Not necessarily. Units used will change the R value - it can be calculated to use any combination of mass, length and temperature units (http://en.wikipedia.org/wiki/Ideal_gas_constant - see the table on the right). The only important thing is that the temperature scale is absolute (as explained in my previous post).
dawin
#5
Dec30-13, 08:14 PM
P: 55
Quote Quote by petersun825 View Post
Generally, yes, you'll see those pairings. Not necessarily just those units--other units will be used besides lbs/ft^3. Fahrenheit is usually used by those that use US Customary units, and we happen to also use lbs, inches/ft, etc, so the pairing is usually natural.
1 Ra is equivalent to a change of 1 F. Whereas 1 Kelvin is equal a change of 1 C.
Register to reply
Related Discussions
Show that when the temperature is such that T<< Debye temperature, the specific... Advanced Physics Homework 1
Energy required for temperature raise - temperature-dependent specific heat capacity Advanced Physics Homework 3
Energy required for temperature raise - temperature-dependent specific heat capacity Introductory Physics Homework 1
How to calculate density from specific weight in imperial units Biology, Chemistry & Other Homework 2
Altitude for Specific Weight Introductory Physics Homework 5
